Old 09-05-2009, 01:34 AM
jamescone jamescone is offline
Default installing nutplates in dificult places
Here is an easy way to install nutplates when you can't get at the back side of the mounting. I used this technique to install nutplates for the ELT antenna bracket that I got in a recent care package from Van's. Go to:
http://picasaweb.google.com/JimCone1...struction9409# to see pictures and descriptions. For some reason, the pictures are small, but you can see them well enough to get the idea. Move your mouse over each picture to get the full text description.
The link worked when I previewed this post but it does not seem to work. I will try to get it fixed and re-post it. Try this link:
http://picasaweb.google.com/JimCone1...09?feat=email#
Jim Cone
5 peat offender
2 - 6a's, 2 - 7a's, and a 12
EAA Gold Tech Counselor
Old 09-05-2009, 02:24 AM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
Jim's pictures;
This is how to bend the wire so that it will let the nutplate lie flat against the place where it will be installed.
__________________________________________________ ______________
Feed the wire down thru the nutplate screw hole and thru the nutplate from the screw side. Then bend the wire as shown in the previous picture.
Pull the wire up and use a pick to align one sde of the nut plate and install a cleco. Then align the other side of the nutplate and cleco it as well.
After installing both clecos, install a screw and tighten so that the nutplate is flat against the surface that it is to be installed to. Remove one cleco and rivet with a pop rivet. Then remove the other cleco and rivet that side and you are done! Easy.
(you have to right-click on an enlarged picture and copy the adress of the picture, do not copy the webadress).
PH-BZT
MyKitlog
Old 09-05-2009, 09:26 AM
MartySantic's Avatar
MartySantic MartySantic is offline
Jim,
What a great idea. Wish you posted this a week ago. Mine are in after fooling around with them o the tip of my finger.
Marty Santic ----- W9EAA
RV-12 N128MS ----- Now Flying
My RV-12 Build Log - http://www.martysrv12.blogspot.com/
Davenport, IA
Old 09-14-2009, 12:01 AM
Gandalf Gandalf is offline
Jim... Thanks for the cool tip. Gagarin737 thanks for posting the pictures.
Jeff
