Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Electrical Systems
Old 11-28-2005, 08:10 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Default Ray Allen Trim Indicator
Does anyone know whether the direction of the trim indicator light bar can be changed by switching up two of the wires in the back? My aileron trim indicator is reversed and since I have decals on the indicator, it would be easier to swap a couple of wires instead of flipping the indicator over and redoing it.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 11-28-2005, 09:11 AM
RV_7A RV_7A is offline
You will have to flip the indicator.
-Jeff
www.JeffsRV-7A.com
N808TX
Old 11-28-2005, 11:00 AM
rglick rglick is offline
Default Trim Indicator
I was curious about it and since I have my panel on the Bench, I threw the Servo, switch and indicator together. If you swap the two white wires (Servo to Switch) around you do get the indicator to swap direction but also the servo moves in the opposite direction. I don't think you want that. Now, if you swap the Orange and Blue wires (Orange to Blue/Blue to Orange) from the Servo to the LED indicator you will get just the indicator to swap direction. Hope this helps.
Richard Glick
RV7A Working on Canopy/Panel
Slinger WI
Old 11-28-2005, 12:09 PM
N62XS N62XS is offline
Default Swap the blue and the orange wires
Had the same problem two weeks ago on my elevator. Called Ray Allen and was told to swap the blue and the orange wires to resolve the issue. Did it and it worked.
Old 11-29-2005, 07:35 AM
f1rocket's Avatar
Thank you very much. That's what I was looking for.
Randy Pflanzer
Greenwood, IN
Paid through 2043!
Old 11-29-2005, 07:43 AM
Jim Kiloh's Avatar
Jim Kiloh Jim Kiloh is offline
Default which connectors
Hi,
I'm just getting to the stage where I need to wire the Trim servos, switches etc. and was wondering what connectors you guys are using? Idealy I would like a miniture 'plug & socket' type connector.
Any help would be appreiciated.
Jim
Houston TX
Panel & Canopy.
Old 11-29-2005, 11:10 AM
Davepar's Avatar
Davepar Davepar is offline
I'm using D-sub crimped pins/sockets and connectors. They're very easy to install. Here's one source:
http://www.steinair.com/connectors.htm
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 11-29-2005, 01:03 PM
pmercier's Avatar
pmercier pmercier is offline
Default Dean connectors
Check out dean connectors found at most hobby shops. Very small and secure fitting. I use shrink wrap for added security. My electric trim used 2 connectors, one with 2 pins and one with 3 pins. Some 5 pin connectors are available.
Philip Mercier
RV-4 Abbotsford BC.
Old 11-29-2005, 03:42 PM
I used Cat 5 connectors and it was a snap. (no pun intended)
www.JeffsRV-7A.com
N808TX
Old 11-29-2005, 09:14 PM
Tom McCutcheon Tom McCutcheon is offline
Default Connectors
I was at Van's the other day and another customer was there getting supplies and also showing Van's a circuit board that would allow you to plug in all of the servos and other items related to an auto pilot system. His board had these small connectors which he said you could get both male and female and are made by Molex. He suggested I check out Digikey dot com. I haven't found them yet but I'm not sure what I should call them except connectors. They are a small connector and looked like they might have maybe up to six or eight conductors. Also, they connect with a positive click, are about 3/4" wide for this many conductors. I guess you can tell I was impressed. I've been looking for that type connector for some time. Post here if you figure out which to order.
http://dkc1.digikey.com/us/pdf/Current.html
Tom McCutcheon
