Old 03-30-2009, 12:46 PM
Default Fuselage addendum and hints part 1
Page 20-02 Figure 1: Get used to optical illusions in the RV-12 plans. Drawings should show objects in the distance as being smaller than closer objects. In these plans, both near and far objects are drawn the same size. That causes optical illusions. In the drawing in figure 1, the left side is closer to you and you are looking up at the part from the bottom. It might help if you cover up the left side of the drawing and just look at the right side.
Page 20-03 step 2: When drilling through thick material, it is even more important to make sure the drill is perpendicular to the work. Otherwise the rivet head will not lay flat on the aluminum. One way to drill perpendicular is to have a helper watch the drill in one axis while you watch the other axis. If you do not have a helper, drill a hole in a scrap piece of wood using a drill press to assure the hole is perpendicular to the surface. Then clamp the wood to the work and drill through the hole in the wood. A third method is to watch the reflection of the drill bit in the work and make sure the reflection is in line with the drill bit. However you do it, just drill a few holes and test them with rivets before drilling the rest of the holes.
Page 20-04 Figure 2: The center section aft bulkhead is labeled wrong. Change F-1204 to F-1204D.
Page 21-02 Step 1: Do NOT dimple the tooling alignment hole.
Page 21-02 Step 4: Notice that the rivet factory heads go on the bulkhead so that the rivets will not interfere with the landing gear installation.
Page 21-02 Step 9 & 10: Do NOT dimple the two screw holes for K1000-08 nutplates in the top flange of F-1206A
Page 21-02 Step 14: Notice that the outside of both bearing brackets are countersunk. The shop heads will be flush. Before riveting the bearing bracket assembly, make sure there is enough room for the bearing. Van's suppliers have had a problem machining the bearing holes deep enough. If your parts are not machined deep enough, one fix is to coat the insides of the side plates with enough paint to make more space for the bearing.
Page 21-03 Step 4: Only 2 rivets are shown to avoid cluttering the drawing. Put in all 6 per rib.
Page 21-05 Steps 10 & 13 refer back to Step 5 when it is actually Step 6.
Page 21-06 Steps 3 & 5 refer to ribs that do not have seat belt attach lugs.
Page 21-06 Step 7: Cut a 20.5" length of hinge. Always cut hinges 1/2 inch longer unless you are sure that the hinge barrels and tabs are on the correct end. It is better to waste 1/2" than 20 inches. Not to worry, there is enough hinge.
Page 21-10: If 2 holes along the edge do not line up, check to make sure that F-1203C is right side up.
Page 21-14 Step 1: You might find it easier to lay the fuselage onto its side so that gravity does not pull the washers out.
Page 21-14 Step 7: The SB500-6 snap bushings are slightly too small for the 3/8" fuel line. Put the bushings into a vise and squeeze the tabs inward. File away part of the tabs that protrude inside of the bushing. After snapping the SB500-6 bushings into place, make sure the fuel line goes through now while you can still easily get at them.
Page 21-14 Step 8: There is no step 8 on the drawing but it needs to be added. Install the bulkhead fuel fitting into the F-1204D bulkhead as shown on page 28-06. It will take you 5 minutes to do it now while you can get at it. After the bottom skin is on, it will take you very much longer and cause you frustration.
Page 21-15 Step 1: Both left and right sides have notches. You are viewing the F-1275 corner skins from the inside (concave) side.
Page 21-18 Step 10: Leave both of the WD-1233 L&R steps off or else they will be in your way. You can install them at any time in the future, even after the whole RV-12 is completed. The bolts will be accessible from inside of the cockpit.
Page 21-20 Step 1: Tighten the nuts to the maximum allowed torque. You do not want these studs turning when you install a second nut later.
Page 22-02 Step 2: Machine countersink the nutplate rivet holes on the firewall side of F-1288.
Page 22-02 Step 5: File away flange of F-1217A-R where it interferes with gascolator fuel fitting through firewall.
Page 22-02 Step 6: Consider attaching F-1201L Bracket on Page 22-03 Figure 4 before riveting F-1217A-R.
Page 22-03 Step 2: Do NOT dimple all 4 of the F-1257 channels. Only do the 3 that support the rudder.
Page 22-03 Step 4: Do NOT rivet the two holes along the forward edge of the F-1201B Firewall Shelf that will be riveted to the oil tank braces on Page 29-05 Figure 1.
Page 22-04 Step 0: Final drill 7/32" the VA-188 two nutplate screw holes to accept #10 screws. Machine countersink the VA-188 for AN426 rivets.
Page 22-05 Step 1: Rivet the vertical flanges first before bottom rivets get in the way.
Page 23-01: Consider installing the fuel system in Section 28 before doing section 23. It will be a lot easier without the sides being in the way.
Page 23-02 Step 3: I used a 3/4" steel water-pipe coupling inside of the angle and squeezed it with a vise. It will be too hard to turn the vise handle if you use anything longer than a coupling. Check the angle with a square and there should be about 1/16 of inch gap at the vertex. The object of twisting is to have the top of the longeron flat and on the same plane for the entire length. You can read how others did this step here: http://www.vansairforce.com/communit...ight=longerons
Page 23-02 Step 4: Figure 1 shows the hammer away from the vise, but the longeron should be struck right next to the vise. When bending the aft end of the longeron, I calculated that the end needs to be bent inward slightly less than 7/16", 27/64" to be exact.
Page 23-03 Step 1: The rivet hole in the corner is not countersunk because the rivet head will not interfere with the roll bar. The plans are correct in case you question it.
Page 23-04 Step 3: Rivet the bottom two holes of F-1203G with LP4-3 rivets.
Page 23-06 Step 5: If you have an older set of plans, it calls for dimpling the side skin flush on the inboard side. Later revisions have changed this to the outboard side.
Page 23-08 Step 1: Cut the hinge 10.5" long. After studying each half, cut another 1/2" off to make it match the picture.
Page 24-02 Step 1: There is no top or bottom or left or right to the F-1231 B&C Roll bar Straps. Bend them in the same direction of their natural curve. Just make sure that the angles at the ends of the straps match the channels. It is the forward and aft edges that must be orientated correctly.
Page 24-02 Step 3: De-burr all holes.
Page 24-02 Step 4: Some builders had trouble with the width of the roll bar not matching the spacing of the roll bar bases. Make sure the ends are the correct distance apart as you rivet. Read what other said about this at http://www.vansairforce.com/communit...light=roll+bar
Page 24-03 Step 1: Leave the bolts in the F-1231D Roll Bar Bases loose until you slide the roll bar over the bases. You can final tighten the bolts with a swivel-head wrench such as the Proto 1270-14. See http://www.grainger.com/Grainger/items/1Q284
Page 24-03 Step 4: If you have trouble removing the roll bar, a 2x2 from a crate, inserted into the lightening hole, makes a good pry lever. Set another block of wood under it for a fulcrum.
Since I built the fuselage before the tail, I had to skip the rest of section 24 and all of section 25.
Page 26-02 Figure 7 is looking at the inside of the angle.
Old 03-31-2009, 09:15 AM
Mark Henderson Mark Henderson is offline
Default Thanks
I appreciate your work in putting all this info in one place.
Old 06-20-2009, 07:04 PM
BigJohn BigJohn is offline
Default Suggestion re: nutplates
Suggest adding Page 21-05 warning about -08 and -03 nutplates. See my new post this date.
?Master Pilot? Award, UFO Member.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
Old 10-13-2009, 03:32 AM
gblwy's Avatar
gblwy gblwy is offline
Default 23-03 five holes or six?
The above-noted hints indicate that the corner hole on the roll bar attach plate does not need to be countersunk, then goes on to say the plans are correct. However the plans call for 5 locations to be countersunk, and Figure 1 has arrows pointing to six holes to be countersunk (including the corner one), so the plans cannot be correct. Should the corner hole be countersunk or not?
Thanks for any guidance...Keith
Old 10-13-2009, 07:10 AM
Default 23-03 Step 1
Keith,
The text in step 1 is correct: countersink 5 locations. However the figure is wrong showing 6 locations. The hole in the forward outboard corner does not need to be countersunk. However, it will not hurt anything if you do countersink 6 holes, just put a CS4-4 rivet in that 6th hole.
Joe
Old 10-13-2009, 02:42 PM
gblwy's Avatar
Default Thanks
Thanks Joe.
I see now, on page 24-03 figure 1, that the Roll Bar Base (F-1231D) will likely cover four of the five rivets on the forward side of the attach plate.
Cheers...Keith
Old 08-25-2010, 08:36 AM
Dgamble's Avatar
Dgamble Dgamble is offline
Default Extra hole in roll bar support plates
On page 23-03, the roll bar support plates are supposed to get six LP4-3 rivets to attach them to the under structure. There are seven holes that look like they need rivets. I riveted the most obvious six and left the questionable hole with a cleco in it. Does a rivet go in this hole later? Usually cases like this come with a "DO NOT RIVET" warning in the drawing; this one did not.
Dave Gamble
Grove City, OH
RV-6 N466PG Purchased already flying - SOLD!
The Book: The PapaGolf Chronicles
Built RV-12
http://www.schmetterlingaviation.com
The Book: Being written.
The above web blogs and any links provided thereto are not instructional or advisory in nature. They merely seek to share my experiences in building and flying Van's RV airplanes.
Old 08-25-2010, 09:27 AM
ARPENN ARPENN is offline
Default Page 23-03
I wondered about those holes and finally filled them with LP4-3 rivets. However, if you elect to install the lighting system, the hole on the right gets enlarged for a snap bushing and provides passage for the eyeball light wiring. I guess you can fill the other side with a rivet so no one will ask what goes there.
Art Pennanen
Old 08-25-2010, 11:58 AM
clucier clucier is offline
Default additional Drill Helper
To solve this problem I took my Rigid Drill, mounted in a vise, measured with a nice carpenters level then attached a small stick on bubble level (the other RV style) on the top and back so that if drilling vertically down or horizontally in, you can easily ensure you are straight in the proper plane. The side to side you should be able to see easily, if not, go to the optometrist before flight testing
Old 12-26-2010, 05:01 PM
Bill_H's Avatar
Bill_H Bill_H is offline
Page 20-03 - I match-drilled the 70-plus holes in place, not on the drill dress. Here is the most important tip for drilling these through that think aluminum - a tip that I have not seen elsewhere: Put BOELUBE on the drill tip for each hole (if you don't have that, some other wax would likely work, but get some.) The chips will just come flying out the hole. I did 3 holes before that and I would have to clear the hole about 3 times and it was not drilling as easy as I thought it should be (with a sharp bit). With a bit of boelube, each hole would drill in about 12 seconds with light pressure using a 2500 rpm electric drill. (For some reason I just like that one better than my pneumatic. I think it is the annoying compressor noise - loud in the shop.) The reflection in the aluminum made it easy to keep the drill straight. With the boelube it is even MORE important to be wearing close-fit safety glasses because those chips do fly out.
