Go Back   VAF Forums > Main > RV Building Tips/Techniques
Old 03-22-2009, 08:27 PM
llavalle's Avatar
llavalle llavalle is offline
Default Tip : Using NAS1097 rivets for nutplate
While working on my last emp part, the left elevator, I encountered my first nut plates with flush rivets.
While reading the forum and the builder's manual, I came across the NAS1097 rivets. Those are commonly referred as "OOPS" rivets. They have a smaller head. i.e. a NAS1097AD4 rivet will have the same head as a regular 3/32 rivets... but with a 1/8 shank.
So anyway, I had those around because I bought the "Avery OOPS Hole saver kit". The kit contains 3/32 rivets with smaller head (equivalent to 1/16 rivets). You can then machine countersink the thin skin (it's too thin to C/S for a 3/32 rivet) just enough and use this smaller head rivet.
Faster and it does look cleaner IMO.
Using those, you don't have to dimple or machine C/S the nutplates. The rivet is obviously weaker but it's only purpose is to prevent the nutplate from rotating.
It might be old news for some (most?) of you but it was new to me and I'd like to share this with others
Philippe Marseille
RV-9A Kit Emp done, wings @50% - SOLD
RV-12iS@Empennage
Construction Web Cam
Old 03-22-2009, 09:29 PM
Doug Knab Doug Knab is offline
Default PLATE NUT RIVETS
The 1097 rivets are the only way to go. I've done hundreds of plate nuts with these rivets and you only need a deburring tool for the countersink.
You have come across a real time saver.
Old 03-29-2009, 07:26 PM
Pbr47906 Pbr47906 is offline
Default Nut plates
All:
I too was trouble with the issue of cs nutplates for the electric trim doubler. However I did some research (Don't tell my mentor) and came upon a method where the skin and the nutplate are dimpled cs at the same time. I practiced on several pieces and am very pleased with the results.
I also read (there I go again) about issues with the electric trim servo that after dimpling the servo would not seat on the bracket. Here I practiced with my deburring tool to form cs the doubler. The servo sat down nicely. That little deburring bit is the best thing in my tool box.
As soon as I can figure out how to send pictures, I will post them.
Ruley
Old 04-01-2009, 12:03 AM
derLuigi's Avatar
derLuigi derLuigi is offline
Default Van's carries them
You can get the NAS1097 AD3 at Van's also (lengths -3 -3.5 -4 -6). They're not listed in the catalog or the webshop but you can order them anyway, you'll get them.
Mario
Mario from Aachen, Germany
RV-7, emp. done, wings close to being ready for inspection, canoe flipped and parts of the finish kit in just about every room of the house
2019 contribution sent - thanks for this awesome space DR
Old 04-03-2009, 09:38 AM
My experience was that dimpling both the skin & platenut actually helped maintain alignment, & it was the fastest method I tried.
YMMV, etc etc...
Charlie
Old 04-03-2009, 01:13 PM
lucaperazzolli's Avatar
lucaperazzolli lucaperazzolli is offline
Great stuff !
Get them NAS (ooops rivets) from Van's or Avery sells a box with various size
my 2 cent
http://www.averytools.com/p-918-oops...rivet-kit.aspx
Luke
Trento, northern Italy
RV-8 QuickBuild, Catto 3 blade Prop, YO-360-A1A. Status : I-LUKE is Flying - 400 h. and counting
http://www.rv8.it
CrewRV8 team leader
https://youtu.be/VhAkhuqZMQA
https://www.youtube.com/watch?v=he9AFHRO1OY
=VAF= 2020
