Go Back   VAF Forums > Model Specific > RV-4
Old 07-13-2007, 05:29 PM
dsgilmer dsgilmer is offline
Default Buying prop strike AC
I am thinking about buying an RV-4 that has had a previous prop strike, and would like to know what I should be looking for to make sure all the required inspections and repairs have been done properly. It was upon landing, and just bent the prop tips. The engine was a Lycoming 0360 with a Hartzel CS prop. I suspect everything is in order, but would like to have someones advice in what exactly to watch out for. Thanks
Old 07-13-2007, 05:39 PM
Mel's Avatar
Mel Mel is online now
Any prop strike, no matter how minor, can cause cracks in the crankshaft. That's why Lycoming requires a complete teardown and inspection.
Mel Asberry, DAR since the last century.
EAA Flight Advisor/Tech Counselor, Friend of the RV-1
Recipient of Tony Bingelis Award and Wright Brothers Master Pilot Award
USAF Vet, High School E-LSA Project Mentor.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 07-13-2007, 05:41 PM
panhandler1956's Avatar
panhandler1956 panhandler1956 is offline
Default Open it up
I agree totally with Mel. My dad is an A&P and he agrees, you can check runout all day long and you'll never know the crank is compromised until..............well you know.
Brent Owens
EAA Chapter 9 Tech Counselor/Flight Advisor
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 08-03-2007, 07:16 AM
the_other_dougreeves the_other_dougreeves is offline
Figure $10k for a new prop and inspection, plus repairs to any damage. Might be less if you do some of this yourself or have a good / cheap A&P.
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 08-03-2007, 09:19 AM
cytoxin's Avatar
cytoxin cytoxin is offline
Default asked this before
and was contacted off line by several engine builders that they rarely did a teardown on a prop strike that revealed a damaged crank. . i would however do it but my point is if it wasnt to bad a strike then the stuff will likely check out... it is however a gamble and you could win or loose. so pay accordingly.
NOTE::: RALRELY DID =THEY RARELY DID FIND DAMAGE AT TEAR DOWN
William Weesner/ still kicking.
Old 08-03-2007, 10:35 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation What Lycoming says...
Lycoming says a full teardown/inspection is needed....
http://www.lycoming.com/support/publ...dfs/SB533A.pdf
This SB includes the Lycoming definition of a prop strike.
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-03-2007, 12:58 PM
N131RV N131RV is offline
Default Prop strike (from experience)
I have experienced two prop strikes. The first was rather major and the second more minor. In both cases I had the engine removed/inspected and the prop replaced/repaired.
First was at OSH on "getaway day" in 2001.
In the first case, the engine was shutdown after I heard the "tinging" of the prop on the concrete. The tips were bent about three inches. The engine was TBO and EAA, bless their hearts, stepped up and paid for my repairs, minus the overhaul cost. Things have changed and if you get damaged at OSH, it's "tough luck" now.
Second time while taxiing at RNT (same airplane).
In the second case, the tips of the propeller had only been deformed about an inch. The engine was inspected and determined to be undamaged.A local prop shop reconditioned the prop and an IA signed it off as serviceable. That was 380 hours ago and no problems since. My total bill for the R&R, engine inspection and prop reconditioning was about $13,500. Avemco to the rescue, I did not have to pay a dime.
By far, the major cost of both inspection(s) was the R&R (remove and replace). If you do the remove and replace, you will save a TON of money. You can in fact, legally remove the engine and tear it down yourself, prior to having the parts inspected, then have a local A&P reassemble the engine.
I was in a certified aircraft and did not have that option.
Just a thought,
JP
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
Old 08-03-2007, 08:32 PM
txaviator's Avatar
txaviator txaviator is offline
Default Speaking of......
I'll never forget...I was with Jay Pratt and a bunch of the local DFW gang, flying around to lunch and then some subsequent fly-in's (which we 'discovered spur of the moment on the radios').
We're on the ramp at one of our stops, and a guys comes taxiing up to the ramp in a -7A. When he shuts down, all I see is about 3" of each prop tip severely bent back. I didn't know how to approach the guy, but finally said "hey, do you know you had a prop strike?" He looked up at the prop and didn't say anything else. A really weird deal.....He fueled up, and took off to who knows where....amazing.....never said a word.......
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 08-04-2007, 05:33 AM
cytoxin's Avatar
Default hmmm
gil in Tucson
SLOW DOWN GIL, READ THE WHOLE PARAGRAPH.
didnt say they or i wouldnt do it, the intent was to say very little ever revealed any damage. with obvious exception to the prop
there was a guy here flying a 182 that had a prop strike with 3-4 inches of his c/s prop bent back. he flew for two months before getting it fixed.
they thought nothing of it..the 172 i fly alot was landed on the beach by a renter,they flew it back....approx 100 miles. it had a prop strike that didnt noticebly bend the prop.. when the student and instructor got in to fly after the weekend they felt a huge vibration... then beach sand was found and following interview revealed the mishap..cost the customer 10,000....hope he was insured.
anyone remember the pics of the 172 that lost the prop inflight to a severed crank. about 2 years ago.. moral of the story..(same as the first. a complete and thorough inspection is required. but it will probally check out ok.)
Old 05-05-2010, 10:13 AM
SKYHAWK405 SKYHAWK405 is offline
Default LYCOMING PROPSTRIKE
Amigo, I prefer the term, "fiscally feasible" over "cheap". We are'nt talkin' about my prom dates here...
I dinged the prop on my O360A$M last week, and although the conventional wisdom was to mic the hub and return to service, the Textron Lycoming Svc Bulletin 533A takes the position that the engine must be torn down and inspected. It leaves anything less intrusive to the responsibility of the A & P signing it off. Avemco was particularly insistent that they pay to perform the tear down. I concur, and I will likely foot the diff and O/haul the engine. You guys are dot on at the tear down cost at 10,000. I am finding quality o/hauls at about 18,000.
On second pass, my A & P stuck me for lunch yesterday, so I rescind or at least qualify my opening statement..
