Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Interiors
Old 06-22-2007, 10:01 PM
Caveman's Avatar
Caveman Caveman is offline
Default Rolling your own interior
The wife and I are thinking of doing our own upholstery on our 7. We have a line on some genuine aircraft fabric and carpet. We have the Van's seat foam and patterns. Can anyone who has done this point us to some "how to roll you own interior" websites or books? Also, sources for backing and piping would be appreciated. Thanks.
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
Old 06-23-2007, 07:11 AM
fstringham7a fstringham7a is offline
Joe
In the olden days as a part time job I reupholstered furniture. It was pretty easy.....except for sewing up (even with an industrial sewing machine) the seat cushions. It was interesting how difficult ..at least for me... to get those corners 90 degrees in all three dimensions. Now add the complexity of all those corners around the stick...........
So Abby (Flightline Interiors) is going to do my seats and I will do the rest of the interior!
If you or your wife has some experience with sewing up upholstery fabric give a it a try!!!! I guess like everything involved with building this plane it can be done with knowledge, patiences, and some good old hard work.
Frank @ SGU RV7A "NDY"
Old 06-23-2007, 08:38 AM
Caveman's Avatar
Default Since the fabric is free
I sincerely appreciate the feedback, Frank. I'm in OKC today, helping my daughter move. We hope to visit a few sewing stores. If I didn't have a line on some inexpensive, (not cheap), aircraft fabric, I doubt I'd consider doing it. Since I blew the budget on the engine and prop, though, we will give it a try and see what happens. I think it would be neat to be able to say, "We did that, too." Anyone else have some advice or websites? Anyone done this and felt satified with the results?
Joe Schneider
Flying since 2008
Old 06-23-2007, 12:11 PM
Joe
Man are you speaking truth when it comes to blowing the budget.......I also think that your wellingness to tackle this project says volumes about all RV builders. JUST DO IT........I would say that you need a good pattern for the seats bottoms and backs. You can design your own for sure and I would say that when you are done the satisfaction of DOING IT will go through the roof. Also check out some upholstery shops either home or aircraft type and get their advice. Many small one man shops would be glad to give you some insight/help/tips on pattern making/sewing/substructure elements. If i can be of any help just give me a call 435-632-6895 and I would gladly give you my .02 worth.
I can't wait to see the outcome of your venture.
Old 06-23-2007, 03:00 PM
zkvii's Avatar
zkvii zkvii is offline
Default mixed results
Hi,
We tried.... I had a Aunt (experienced tailoress) on holiday last year and changed tacks and did the seats. The basic stuff came out ok - I Would suggest adding 1/4" to the 'height' of all sides of the VANs seat plans.
Set of photos at http://www.rvproject.gen.nz/upholstery.html - sorry no words - I was working long days whilst doing this.
The major problem we have is getting the 'center' to lay flat / get the seam edge to hold down. I think probably it needs a industrial sewing machine that can hold the distance between the top and bottom surfaces (~2") whilst stitching.
Overall great learning experience for me - "just another skill" - one of the best bits of building for me, the breath of learning..... - just enough to be scary!
My current plan is to use what we have got for flight testing and 'scrub' use, and as the FX rate UK-US is in my favour probably splash out with DJ or Abby next year and upgrade / complete the interior once I have a bit more experience in what I want.
My .02,
ZK-VII - RV 7A - New Zealand - NZNE - 700 hrs (2008 -2020)
TMX OF-360 (FADEC), Dual GRT H1, Garmin 430 / SL30 / 327, TT VSVG
Old 06-23-2007, 03:52 PM
mark manda's Avatar
mark manda mark manda is offline
here's another excellent page on rolling your own.
http://www.vincesrocket.com/upholstery.htm
Old 06-24-2007, 09:10 AM
Caveman's Avatar
Mark & Carl,
Thanks, This will get me started. I appreciate your help.
Joe
Joe Schneider
Flying since 2008
Last edited by Caveman : 06-24-2007 at 09:12 AM. Reason: Hit the enter key to soon.
Old 07-05-2007, 04:57 PM
MrNomad's Avatar
MrNomad MrNomad is offline
Smile side panel backing - ideas please??
My seats are done, it's time to do the side panels and the wife agreed to handle this job. All we need is some kind of fire proof cardboard or hardboard so that she can glue the fire proof batting and material to.
Any suggestions & sources for fire proof cardboard or hardboard would be greatly appreciated.
Barry
RV9A - almost done
Old 07-06-2007, 11:47 AM
az_gila's Avatar
az_gila az_gila is offline
Smile Alum.
Barry
RV9A - almost done
Barry... 0.016 alum sheet should work and be fire-proof...
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-07-2007, 03:27 PM
SebsRV7A SebsRV7A is offline
Talking Foam for side panels
Barry
RV9A - almost done
I used extra foam I had for the floors and used spray adhesive to secure the cloth. The foam is the light fire resistant stuff from Spruce. I used 3/8" and 1/2". Cut a paper template for each piece and transferred to the foam. The pieces stay in place on their own.
Sebastian Trost
RV-7A flying
O61
