Old 02-13-2020, 04:16 PM
olyolson's Avatar
olyolson olyolson is offline
Default Main tire inner tube
About to replace the tires on the next annual and will replace the tubes as well. Aircraft Spruce has what I think is the correct tire for my RV-8 but not 100% sure. The description is:
097-500-0 15x6.0-6 Michelin Airstop Tube 06-01373 $83.75
Or Vans has this one:
5:00X5-6 Main Gear Tube for one and two place RV's and RV-10 nosewheel $59.00
Are the Michelin tubes that much better than what Vans offers? Are both of these the correct ones?
RV-8, Flying
Previous airplanes: Corby Starlet, Citabria, Cessna 140, Vari-Viggen, RV-3, RV-4
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
Old 02-13-2020, 04:28 PM
RV6_flyer's Avatar
Oly:
The RV-8 uses the same tire as the RV-6. 5.00 - 5
I believe that Airstop tube you list is the incorrect tube. Van's tube is the correct one.
I believe you want / need the $118.75 tube. (I paid around $35 for mine about 20-years ago.)
MICHELIN AIRSTOP TUBE 5.00-5 BNT90 097-908-0
Part# 06-00019
MFR Model# 097-908-0
I would pay the extra money for the Michelim Airstop tubes. I add air to them once a year. The tube Van's Aircraft furnish with the kit needed air every 30-days when I live in Kalifornia.
The builder / owner of your RV-8 was using Wilkerson Aircraft Retreads and turned me on to them years ago. Not sure what their price is but last purchase was $55 with their core delivered. It is necessary to PHONE them to place an order.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Last edited by RV6_flyer : 02-13-2020 at 04:31 PM. Reason: change have to list / change one to once
Old 02-13-2020, 04:59 PM
RV8JD's Avatar
RV8JD RV8JD is offline
On my RV-8s I've used the Michelin Airstop Tubes, 500-5, with the TR67 valve (bent 90 Deg.). I've been quite happy with them.
I usually buy them from Desser or ACS, along with tires. It looks like Michelin replaced the older P/N 092-308-0 with P/N 097-908-0, according to ACS. Here are the Desser links:
P/N 092-308-0:
https://shop.desser.com/pc_product_d...6DBEEA2FA8B9CE
Or:
P/N 097-908-0
https://shop.desser.com/pc_product_d...700D461CDC8E11
Carl N.
Arlington, WA (KAWO)
RV-8, 790 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 02-13-2020, 05:57 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
P/N 092-308-0:
Or:
P/N 097-908-0
Same tube, different price, love that creative marketing !!
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 02-13-2020, 06:31 PM
Jake14 Jake14 is offline
slightly off-subject, but is the standard procedure to always replace the tubes when replacing the tire? I kinda hate to toss out a good air-stop tube if it's not necessary....
RV-14A flying 410 hrs
Old 02-13-2020, 06:35 PM
Sam Buchanan's Avatar
been here awhile
It is standard procedure for those who are convinced you must replace the tube when replacing a tire......and not standard procedure for those who aren't convinced the tube must be replaced when replacing a tire...............
Sam Buchanan
RV-6
Fokker D.VII replica
Old 02-13-2020, 06:40 PM
JDeanda JDeanda is offline
Default Tubes & Tyres
I'm an A&P, and I’ve always seen in print that that the recommended thing is to replace tubes with tires, but I've replaced lots of tires while reusing the tubes. No problems with it so far, as long as the tube is in good shape. We use the leakproof tubes in our RV-6 and love 'em. We too add air about once a year. Also we use the tires from Vans... no problems so far.
Old 02-14-2020, 08:37 AM
RV7 To Go RV7 To Go is offline
For the last 7 years I have had good luck with the Aero Classic Leakguard tubes from ACS. Only add air once a year when the weather gets colder. About half the price of the Michelin's.
The maintenance department for our flight school of 28 planes noticed a significant reduction in flat tires when they started replacing tubes at every tire change a few years ago. The tube cost was more than offset by the labour and aircraft downtime cost savings.
Personally I inspect the tube for chaffing and creases. If it looks good I will reuse it once before replacing. Use a good amount of talc or baby powder when reinstalling. Works for my piece of mind.
Al
___________
RV4 - Bought 2013 Sold 2017 after 450 hrs
RV7 - Built in 6.5 yrs & Flying 2017
Old 02-14-2020, 09:03 AM
Pilot135pd's Avatar
I echo the experience. Since they came out I've always replaced mine with the Aero Classic Leakguard innertubes and Michelin tires. I've added air when it got cold and replaced tubes when I replaced tires. Don't know what I have in inside mine now but logbooks say "replaced tubes & Airhawk tires" 2 years ago. I did notice that I've had to add air a few times in the last year.
Old 02-14-2020, 11:08 AM
Sue Sue is offline
Default Tube size
The 15X6 is for cirrus or c-210 aircraft
you want the 5X5(-6)
