Old 01-22-2020, 11:24 AM
iaw4 iaw4 is offline
Default BRS Parachute for 6A
has anyone installed a BRS parachute in an RV6A?
it's purpose would not be primarily to rescue me, but to comfort my wife...although I can see that it could be useful if I do spin training or the like.
Old 01-22-2020, 01:45 PM
AlpineYoda AlpineYoda is offline
I?m planning to build one into my RV-10 at the appropriate time. I?ve contacted BRS Aerospace directly for information and they have been very responsive and helpful. For the RV-10, they make an off-the-shelf panel replacement, but I think the -10 is the only one.
I?m in a meeting and typing this under the desk, so I don?t have the respective weights of the 6 and 10 in front of me. It seems logical that you could simply install the -10 ejection panel in a -6, assuming the weight of the plane is similar enough you won?t get some kind of bad chute deployment. Assuming you could install it in a -6, the big question becomes the fairings for the cords. The -10 kit comes with housings / fairings and anchoring points all built to fit the shape of a -10. You would likely need to either heavily modify all of that for a -6 or make it from scratch.
As I said at the beginning, though, the people at BRS have been really responsive. If you ask, I?m sure they will answer!
RV-10 build blog -- https://eaabuilderslog.org/?blproject&proj=7ZSwfzr2g
Tail finished March 2020
Wings finished July 2020
Fuselage joined to tailcone on July 19, 2020
N1814T reserved with FAA
Donated through 12/31/2020, EAA and AOPA member
When it absolutely, positively doesn't matter when or if it ever gets there, ship with Old Dominion.
Old 01-22-2020, 06:08 PM
N941WR's Avatar
N941WR N941WR is offline
Check to see how much it will add to your empty weight.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-22-2020, 09:08 PM
82 pounds for the -10 version
They do make one for the -7 and -9 that weighs 41 pounds, too
Old 01-23-2020, 01:47 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Here you go (RV6 has the same basic fuselage as RV7 and RV9):
https://www.youtube.com/watch?v=0YtXWj2DI7g
I absolutely saw a DIY BRS installed on the web 15 yrs ago. It was very crude looking installation and was still a project at the time.
Understand the wife issue. I hope you can dissuade your wife. I know the argument is what happens if you have the big one in flight? Answer get a medical and assure her you are a fine human specimen and will out live her.....
Get her a few intro flight lessons. At least if you go flying she will have a chance to land the plane.... If you put a two axis autopilot in and show her how to use it, that might help.
What if engine quits. Fact is engines rarely quit if aircraft is well maintained (statistics don't lie). If it does quit the aircraft can glide to landing. The RV has a lower stall speed than a C-152 which means the landing even if rough it will be easily survivable. Flying in the RV will be safer than driving to the airport if you don't fly in bad weather or run out of gas (and you maintain proficiency and currency)... both easy to avoid rubbing a few brain cells together.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 01-23-2020, 02:48 PM
N941WR's Avatar
WOW! That is a lot of weight pretty far aft.
You had better think twice.
It seems just a bit odd to me, if you are that concerned about safety, why are you building and flying an amateur built aircraft? Wouldn't you be better of with a factory built aircraft?
Just seems like like a person trying to have the safest aircraft available, wouldn't fly a kit, or a single for that matter.
Bill R.
SC86 - Easley, SC
Old 01-23-2020, 05:23 PM
andrewtac andrewtac is offline
My wife is scared in my 8. I wanted a 10, and thought I'd show it to her hoped she'd want to travel in it with me. The smallness, and bubble canopy are contributing factors. Most all of it is irrational fears. Like she wants to fly at 500' and feels much safer than at 10k. I try to explain engine out glide, birds, etc doesn't matter. I did a go around (that I know I could have landed) just to be extra safe and she almost had a heart attack, I tried to explain how it was doing the conservative thing, again irrational fear. She has wrecked every car she has owned (most of them multiple times), some of her friends will not ride with her, I almost never let her drive. She is very comfortable driving 1000 miles to meet me somewhere rather than ride in my well maintained airplane, and I fly for a living. Anyways, long story short I was going to keep the BRS as a trump card to convince her it was safe so I could build a 10. After thinking about it for a bit, I decided not to mention it (as I'd probably almost always do a forced landing over a chute deployment, likely never need it (statss), and it would kill some useful load, increase fuel burn, and slow me down some). However, I understand the why. I can't convince my wife to overcome irrational fears.
Mark Andrew Tacquard
RV8 N189DK
RV10 in progress
Old 01-23-2020, 06:33 PM
Northernliving Northernliving is offline
This was discussed here a few times. Here is one thread with a photo of N180WC that has the BRS built in.
http://www.vansairforce.com/communit...ad.php?t=61559
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 01-23-2020, 10:38 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
You want my prediction? Neither the BRS nor a 10 will change anything. She's afraid of flying, and unless and until that fear is overcome somehow, all the talk, plans, safety enhancements, etc., will be for nought (not to mention, complicating the plane and adding weight).
If you really want her to fly with you, you need to work with her to address the underlying issue: her fear of flying. It might be something about small planes, maybe not. Dunno. Not a shrink.
And you may ultimately have to accept the fact that she's never going to get over it. Hopefully not, but it's a possibility.
2019 Dues paid!
Old 01-23-2020, 10:52 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
I have a friend who is a CFII, an FAA volunteer safety representative and one of the safest pilots I’ve ever flown with. Yet his wife (sadly now deceased due to cancer) never would fly with him...even for trips to visit grandkids in California. So they compromised; he bought her an airline ticket, and he flew the homebuilt airplane...for every trip.
My advice to you is build the plane you want, and find a satisfactory compromise for both of you.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
N79599/ADS-B In and Out...and I like it!
?Certainly, travel is more than the seeing of sights;
it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
