Old 08-13-2019, 01:37 PM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
Default Proper Rivet Height
Hello all
I have noticed a difference when I use flush vs non flush rivets as far as the rivet measuring tool.
On flush rivets the shank of the rivet when Vans calls for a 3-3 for instance is the correct height if I am measuring from the flat part of the skin. If I measure from the top of the dimple it is consistently short.
Going up one half size makes it correct and when driven seems to have better dimensions.
Everything I have seen always shows non flush rivets in the examples on correct formed head dimensions. Is there something I am missing on flush rivets that they can be shorter?
Pete
RV14A Tail kit build mostly done
Wing kit in progress
RV 14 WIKI in process, residing on Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
change dot org link http://chng.it/KBPtXZYD
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 2018,19,20 Military exempt but paid any way Cause its worth it.
Old 08-13-2019, 02:45 PM
Are you sure your dimples are properly nesting? No space between top and bottom pieces?
And yes, sometimes, if the correct rivet length is between sizes, Vans will specify one that's a bit short - especially if the load is in shear. This is a builder judgement call - if 1/2 length extra looks better, and can be driven without bending it over, then used it and move on.
Old 08-13-2019, 04:16 PM
HAL Pilot's Avatar
Aloha Bob
Yes the dimples nest well together. Using Substructure dimples inside and normal on the skin.
Sent a question to Vans also, will post the reply here.
Pete
EAA 1300
Old 08-13-2019, 04:19 PM
HAL Pilot's Avatar
From Sterling at Van's
When a shorter than optimal rivet will still produce a satisfactory rivet head we will typically error on the short side, section 5 describes this in more detail. Ultimately you should measure from the face of the dimple and not the flat sheet. In some cases you may find a buildup of tolerances that may result in a rivet being short and not meeting mil-spec but this is rare.
Pete
EAA 1300
Old 08-14-2019, 07:33 AM
FinnFlyer FinnFlyer is offline
Default Dimpled skins require longer rivets
https://drive.google.com/open?id=1nG...oAZLOLxYqN6gXp
Dimpled material next to shop head requires longer rivets than countersunk.
Finn
N214FL RV-4 -- Building
N46AZ RV3-B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
Old 08-14-2019, 09:44 PM
HAL Pilot's Avatar
Thanks FinnFlyer
That's what I have been seeing. Just wanted to make sure I was using the gauge as intended.
Pete
EAA 1300
