Old 05-06-2019, 09:21 AM
Godo Godo is offline
Default Can't see Dynon files in Savvy's site
Hi,
Since I came accross the SavvyAnalysis.com site, I've been uploading all my flights. Approx two months ago, I started to have difficulties in visualizing the files: They would still load as usual, but files won't be displayed.
I went through the Excel file and I figured that the column "GPS Date & Time" does not have the usual date and time format, but a simple "UNKNOWN_DATE_TIME". Rest of data fields are OK.
As date and time are supposed to be downloaded directly form the GPS signal I suspected a system error, so I've updated my classic Skyview to the latest 15.3.3 release, but did not solve the problem.
Just checked the Dynon forums and found a couple of guys with the same symptoms but (like me) without ideas for resolution.
Did anyone experienced the same? Any ideas?
Thanks in advance,
Godo
Old 05-06-2019, 10:50 AM
Flying Canuck Flying Canuck is offline
If you use Excel, don't save the file afterwards. It will mangle the contents which will give you exactly what you are experiencing. If you want to strip something out of the log files, use a regular text editor (like notepad) and delete whole lines only.
Claude Pitre
RV-9A #91081, C-GCPT
Dynon SkyView HDX, IO-320 and WW 200RV C/S. Flying as of August 6, 2018
Interactive map of all of my flights here
Old 05-06-2019, 02:15 PM
j-red j-red is offline
I have the same issue. Posted about it over on the Dynon site. This seems to be the issue:
If you still have the GPS-250, it has an issue with the calendar roll-over that happened last month. A fix will be out shortly, according to Dynon support.
http://dynonavionics.com/cgi-bin/yab...56055232/17#17
Rebuilt RV-6A N94CR
RV-8 N803DR completed, flying.
Old 05-06-2019, 02:42 PM
Thanks!
I just received the following message from Dynon Support:
Early manufacture GPS 250 built before 2012 have been affected by the GPS Rollover date of April 6, 2019. Symptoms include no date or time being listed in the GPS Fix Status page and clock displayed on SkyView displays is shown as dashes with no valid time. Note: Displays with backup battery installed might still show the date and time, but other problems like winds aloft errors, etc. might exist. Here are the links
to the software to correct this issue.
SkyView Classic
SkyView HDX800
SkyView HDX1100
Really efficient support!
Godo
Old 05-06-2019, 02:48 PM
...and now with the correct links!
SkyView Classic:
http://dynonavionics.com/cgi-bin/yab...te_Classic.dup
SkyView HDX800
http://dynonavionics.com/cgi-bin/yab...ate_HDX800.dup
SkyView HDX1100
http://dynonavionics.com/cgi-bin/yab...te_HDX1100.dup
Old 05-17-2019, 03:43 PM
Aggie78 Aggie78 is offline
Default Latest Update for this Issue
So I emailed Dynon to see if the link provided was still relevant...come to find out there's been ANOTHER update for this problem.
I've tried to copy/post the link address, but for some reason is not copying.
Contact Dynon to get the files/links sent to you for the latest versions.
RS
May 17, 2:16 PM PDT
Hello,
Here are the links to SkyView Software Ver. 15.4.4.5456. This version corrects the GPS rollover issue which caused early vintage GPS 250 antenna / receivers to report an invalid time and date to SkyView. Anyone with an early GPS 250 should load this software to correct the issue. Even users who installed the first fix software Ver. 15.4.3.5287 should load this software as that version had an error which caused the date and time to become invalid after May 6th.
Rob Schroer
RV-7/N75WV
YIO-360-M1B
T67-Hicks Airport, Texas
VAF Monthly Donor
Old 05-18-2019, 07:46 AM
Don Jones's Avatar
Don Jones Don Jones is offline
Default Another Fix
RS
May 17, 2:16 PM PDT
Hello,
This is true, there is indeed a fix for the fix so to speak. There was a math rounding error in the first fix software that again caused the date and time to be invalid. We do have another version out to correct that issue.
SkyView HDX 1100
SkyView HDX 800
SkyView Classic and Touch
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 05-19-2019, 01:02 PM
Default It works!
Thanks Don,
Loaded the patch, tested, and the files are 100% operational again.
Great support, thanks!
Godo
Old 05-19-2019, 04:14 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Is this patch for all Dynon systems with the GPS-250 or just for those in the RV-12?
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 05-19-2019, 08:48 PM
Don Jones's Avatar
It is for any Dynon system with the GPS 250 from around 2012 or earlier.
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
