Old 05-01-2019, 06:44 AM
08FATBOY 08FATBOY is offline
Default Cotter pin
I'm looking for the cotter pin part number for the main wheel axle nut. I checked the assembly manual and the Matco manual, both reference pins but don't supply part numbers
Thanks, Rod
Old 05-01-2019, 06:48 AM
KAdriver's Avatar
KAdriver KAdriver is offline
Tractor supply buy the assorted kit. Match it up
Jason
RV6
KASD
Old 05-01-2019, 07:02 AM
skydiverlv skydiverlv is offline
check your email fatboy, I sent a link. You will never need to order again.
Larry Vandegrift
ULPower 260is
445 hobbs since 7-16
Old 05-01-2019, 07:57 AM
Tony_T's Avatar
Tony_T Tony_T is offline
Thanks, Rod
The correct cotter pin for the Matco axle is Matco part #MSC.125X2COTTERPIN - COTTER PIN Z/P. http://www.matcomfg.com/COTTERPINZP-idv-3325-35.html
The description is misleading as it is not a .125 cotter pin but, I think, a metric size that is slightly smaller diameter. A 1/8" cotter pin is nearly impossible to put in the hole. The Z/P probably means zinc plated as the pin is silver in appearance.
Tony
E-LSA RV-12 ULS
Old 05-01-2019, 10:42 AM
Default Cotter pins
Thanks for the Matco part number
