Old 04-20-2019, 03:36 PM
gwav8or gwav8or is offline
Default 7 tail on a 6?
Was talking to an RV8OR the other day and they mentioned the possibility of putting the tail of a 7 on a 6. Is this even possible?
Old 04-20-2019, 04:15 PM
mike newall's Avatar
The standard upgrade is to replace the fin and rudder with that from an 8, not a 7.
Several been done.
Donated in 2020
Old 04-20-2019, 04:50 PM
RViter RViter is offline
Default Considerations ...
Several been done.
Installed the -8 VS/Rudder on my RV-6A during build. It's one line-item to get all the components, making it easy to order. Adds surface on the VS and rudder. It's 0.020 skin on the rudder. And, it is all factory pre-punched, facilitating assembly. The TE is rolled, not the 'wedge' and it's still possible to get 'curvature' in the TE by rivet sequencing and techniques. (Ask how I know?)
It weighs more than the 'classic' VS/rudder (-6/6A), can't tell you wt or surface area differences but it is more of both. Consideration; if you build a 'light' plane the CG effect may be a factor. My standard FP Sensenich prop, light-wt SkyTec starter, FWF Odessey battery and PlanePower alternator vs a CS prop are factors.
My CG is mid-range to aft CG in almost every load configuration, never in forward range. Keep in mind the potential impact on exceeding aft-CG limits. I'm happy with all the flight characteristics but have no experience with a Classic VS equipped config. I do W&B for all flights and monitor 'weight creep' (junk in the baggage area). Not paranoid or worried but would be aware of it. [Empty 1064 Lbs CG 71.0]
Did NOT offset the VS, straight down the center line. Standard lead weight (per plans) in the rudder, not 'balanced' otherwise.
gary
RV-6A QB Tip-Up, 1st Flight 3/18/17
O-360-J2A (modified & F/I), Sensenich FP (cruise)
VP-X Sport, Dynon SkyView, VFR day
(FFZ) Mesa, AZ - N234GB -
www.mykitlog.com/garyc
Old 04-20-2019, 05:33 PM
Mark33's Avatar
Mark33 Mark33 is offline
Default 7 (9) rudder VS 8 rudder
I don?t know if there?s any difference in the 7 or 8 VS, but the rudder is definitely different. I?m building a -7 but I?m incorporating an 8 rudder. So, if the 7 and 8 VS are the same then I?m sure you could choose which rudder you prefer.
The 7 rudder (which is actually a 9 rudder) is larger and will supposedly give you more authority and better spin recovery. The early 7?s came with the 8 rudder but at some point Vans decided that the 9 rudder was more forgiving. How much it really matters in normal everyday flight is above my pay grade, but I haven?t heard of anyone that?s replaced their 8 rudder for a 9 rudder.
I personally like the looks of the slightly smaller 8 rudder and the skins are definitely thicker. Hopefully they?ll be a few people chime in that?s replaced their 9 rudder with the 8 rudder and give a pirep on any differences they?ve experienced in the flight characteristics between the two. Once again, I?m in the building phase, so I can?t give any firsthand experiences yet.
Old 04-20-2019, 06:26 PM
catmandu's Avatar
catmandu catmandu is offline
I went down this road. Because of weight (cg), for a -6 you can put an early -7/current -8 tail on it, but not a late -7/current -9 tail on it. Clear as mud?
Mike C.
Sierra Nevada
RV-6A bought flying
Old 04-20-2019, 08:04 PM
I appreciate all the replies. I honestly expected some snarky comments like I normally get in another (Certified Aircraft) forum. So I really do appreciate the replies.
I?m thinking of buying (1-2 years out) an already built 6 and was wondering about the feasibility of replacing the tail with a larger rudder from a 7. Looks like replacing with an 8 rudder is more feasible. Is it possible/feasible on an already flying 6?
Old 04-20-2019, 08:57 PM
BillL BillL is offline
Yes, but look carefully, it might be exactly the same. Check skin thickness. .016" or .020".
Bill
Lord Kelvin:
“I often say that when you can measure what you are speaking about,
and express it in numbers, you know something about it; but when you
cannot measure it, when you cannot express it in numbers, your knowledge
is of a meager and unsatisfactory kind.”
Old 04-20-2019, 10:10 PM
rvmills's Avatar
rvmills rvmills is offline
I replaced the original VS and rudder on my RV-6 after owning it for a few years. Very straight forward, no complications in installation at all. I didn't even need to modify the empennage fairing (that may have been lucky though).
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
President/Sport 47/49, Sport Class Air Racing
President, Formation Flying Inc (FFI)
Flight Lead, Lightning Formation Airshows
Old 04-21-2019, 12:08 AM
WingsOnWheels WingsOnWheels is offline
I have a -7 tail on my -6A. There were no huge differences in the installation. Had to rework the intersection fairing though.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
I donate every year on my B-Day (in Dec), but donated early in Sep'19.
Old 04-21-2019, 09:15 AM
Snowflake's Avatar
Having flown my original rudder -6 for about 10 years now, i'd ask why you'd bother changing the rudder if you didn't have to...
Rob Prior
