POSTING RULES
Donate yearly (please).
Advertise in here!
Today's Posts
Insert Pics
03-04-2019, 07:30 PM
Lose 5-10 knots with a 3 blade prop on a 10?
Spoke to Vans support today. They (one guy) thinks I'll lose 5-10 kts with the Hart 3 blade prop over the two blade. Is this true? My RV10 will have a Thunderbolt 260hp and POSSIBLY a 3 blade. I sure as snot don't want to lose 10 kts! Any truth to this?
Bob
RV-10 QB Here 8-25-19
My brain shows a remarkable capacity to not willingly accept information that it considered useless.
03-04-2019, 07:36 PM
True with the MT. Not sure about any other brands.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
03-04-2019, 07:37 PM
So you lose that much? 5-10 knots??
Bob
03-04-2019, 07:41 PM
Yep. I'm afraid so.
David Maib
RV-10 N380DM
VAF Paid 1/21/2020
Jackson Browne
03-04-2019, 07:55 PM
Data please
I am very skeptical that there is a 10 knot loss with a 3 blade compared to the two blade. I would believe 2-3 knots...maybe.
If you have definitive, not anecdotal data, please share it...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
03-04-2019, 09:01 PM
Absolutely correct. Couple of knots at most. Verified by racing my 3-blade MT against 2-blade Hartzells at last year's Race for Rhinos. At one stage I spent the best part of an hour 100m or so behind a 2-blade. Tried everything I could to close the distance but couldn't. Eventually he just drew away - maybe 1/2kt. There were a total of 6 -10s at the race and I was the only 3-blader, Results showed us all within 2kts apart from one who was about 4-5kts faster than anyone else - no-one could work out why (supposedly stock aircraft  ). He ended up on the podium.
On the plus side - super smooth and (supposedly) better TO and climb performance. Plus the cool factor   Only real downside is getting the lower cowl on and off. Some mods needed to the lower cowl. After a while, you get the hang of it.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
03-04-2019, 11:23 PM
Posts like Paul?s above mean nothing; there?s too much variation from plane to plane. The only good test is A-B on the same plane. I?ve only seen one such post; that owner put his 3 blade up for sale after trying a 2 blade and gaining 5 knots, iirc.
03-05-2019, 01:34 AM
A little harsh, I think ......
It was a reasonably sized sample so I think the comparison has merit. Again, apart from the one aircraft, not only were we within a knot or 2 of each other, we were also within a knot or 2 of our handicap speed.
Having said that, 2 knots would be worth some 2 minutes over the race. I'd like to try a 2-blade to see what benefit it gives and then swap out for the next race. Full time though, I wouldn't want to give up my MT - love it.......
Paul
2019 Donation Made
03-05-2019, 04:04 AM
+1 to harsh
Our 3 blade MT 7 will keep up with a 2 blade Hartzell without any issue.
Besides, how often are you running flat out ?
Ultimately, you look at what you want out of your aeroplane and look at the pro's and con's of 2 or 3 blade props. 3 blade is smoother and in our case, the MT has phenomenal acceleration and deceleration, it's smooth and quiet and I cruise just fine at 145kts at 23/23.
Donated in 2020
03-05-2019, 04:44 AM
Super Moderator
To each their own.
Saying the other airplane was faster because one had a 2 blade and one had a 3 blade means nothing.
The only way to verify for sure is to take the same airplane, at the same weight and power settings, and fly it under the exact same atmoshpheric conditions (pressure/temp/altitude, etc). Period.
BTW, we did that with my RV-10 (swapped props) and noticed no measurable difference in speed. We even took my RV-10 back to the mothership and let Van fly my airplane right next to the factory RV-10, with both Van and I in mine (Van doing the flying) and Ken Krueger flying the company RV-10. At 8500' and full throttle, we were neck and neck. The GPS's on each airplane were within 1 knot of each other. Everyone was surprised.  Without swapping the props it still didn't mean anything except it put to rest all of the hullabaloo that the MT is 10 knots slower.
There are advantages and disadvantages to each prop. one might be smoother, have more ground clearance, and better climb performance. The other might be more durable on unimproved runways, easier to get cowling off, cost less, etc..
Racing is a totally different arena.
Build the airplane for you.
Vic
 Vic Syracuse
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
