Old 01-03-2019, 06:37 PM
N941WR's Avatar
N941WR N941WR is offline
Default RV-7 & RV-9 Firewall Penetrations
The following images should help builders in the early (firewall) stage of assembling their aircraft.
Some of these images came from optional drawings that most purchase later in the project. The drawing number is listed above each picture.
In addition to these pictures, I recommend putting platenuts aft of the firewall for the battery box, Gascolater, brake reservoir, Pressure Sensor Manifold, and any other component that may require future maintenance. (For example, removing the battery box after construction is complete requires two people, one in the footwell and one at firewall, if built per the plans.)
My apologies, for some reason the picture hosting site I am using rotated the pictures and I cannot turn them upright.
Oil Pressure, Breather, and Pressure Manifold RV-7,8,9
Drawing OP 27
Gascolator Carb Fuel System RV-7, 9
Drawing OP-28
IO-360 Fuel System, RV-7
Drawing OP-32
Firewall fuel line stiffener for fuel injected engines
Firewall Doubler - Fuel Injection
Drawing OP-32
Firewall electrical penetration for left hand battery location, RV-7, 9
Drawing OP 30
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
