Putting on Engine Mount?
How hare should it be to get the bolts through the holes on the engine mount in the holes in the firewall? Is there a trick to putting on the engine mount?
I can get 5 of the 6 bolts in place relatively easily, but they don't slide into place. I have to use a ratchet wrench while pushing with my hand to get some of the bolts in then the last top one is a nightmare. After I finally got it started, I really had to work to get in into place and while doing so, the coating on the outside of the bolt is scraped off. In addition the bolts on top seem to be canted out on both sides. Will this fix itself when tightening. Is the bolt which the outside coating still OK to use.
I must be missing something about putting on the engine mount. This is the first part that I have tried to put on that is not lined up correctly.
Anyone else have issues?
Ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
