POSTING RULES
Donate yearly (please).
Advertise in here!
Today's Posts
Insert Pics
06-10-2018, 08:41 PM
Help with a Garmin autopilot issue
Okay, so the other day after takeoff I engaged my Garmin autopilot (my setup is a G5, GSA28 pitch and roll servos, and a GMC 307). I used the CWS/disconnect button on the stick, and the autopilot engaged at the existing pitch and roll. I love that feature.
I then configured it to follow the flight plan in my Garmin 430W (using the NAV button on the 307) and to go to my first assigned altitude, using the VS mode. All seemed to be going fine.
Instead of turning left at the first waypoint as planned, however, the autopilot ran the aileron trim all the way to the right, and then disconnected (yellow flashing AP). I got the aircraft back on course, centered the trim, and tried to engage the autopilot again. The same thing happened (trim right, then disconnect), followed by an AP with a red slash through it. I then got a red AFCS indication at the top of the G5. At that point, I was unable to turn the autopilot on, and neither the heading nor altitude dials on the 307 had any effect. So I hand flew from that point on.
After landing, on the "device info" page, the servos and 307 were grayed out. There was one "transmit error" logged.
Still on the ground, I recycled the breaker and at that point, the autopilot and 307 came back to life. The autopilot now turns off and on. I now have green checkboxes for the servos and 307. I ran the preflight test set forth in the manual and again everything seemed to be working correctly.
Since then, I've powered up and down several times, and the system seems to come up fine after the "PFT" indication.
I haven't flight tested it yet. Before doing so, does anyone have any ideas regarding what may have caused this failure? I'm running the latest 5.20 software, for what that's worth.
Doug
N929JA, 2007 RV-9A
Based W96: New Kent International Aerodrome
(near Richmond, VA USA)
2020 Dues Paid
06-11-2018, 05:52 AM
Lots of people misinterpret how to test the autotrim. On the screen they press “test” and then the trim “left” and “right” options on the SCREEN become available. They then proceed to use the stick buttons to “test” instead of the screen buttons. Good chance the autotrim is reversed.
Oh yes, version 5.9 is the latest!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
06-11-2018, 06:03 AM
I always suggest folks first test the AP with autotrim turned off to be sure the basic operation of the AP is working good before activating autotrim.
And I agree with Jon, sounds like the ail autotrim make be backwards.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
06-11-2018, 06:47 AM
Doug
Hello Doug,
As others have commented, it is possible that the auto-trim is reversed (see this thread for more information), but the autopilot doesn't disconnect for out-of-trim conditions.
You are, of course, welcome to continue to solicit help here, but we recommend you contact us directly so we can assist you in collecting a flight data log which will contain the reason for the in-flight disconnect.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
06-11-2018, 06:50 AM
Jon, it doesn?t sound like Doug has a G3X Touch, just a G5 with autopilot. Version 5.20 is the latest software for the G5. The 5.90 is for the G3X Touch.
Mark Hansen
Indianapolis, IN
RV-7A N896PS
Flying
06-11-2018, 08:13 AM
Oops! Missed that. Thanks, and I?ll be sure to RTFQ in the future!😳
Jon Thocker
Habitual Offender
06-11-2018, 08:16 AM
Sounds good, I'll data log my next flight and contact you directly.
Originally Posted by g3xpert
Hello Doug,
Steve
N929JA, 2007 RV-9A
2020 Dues Paid
06-14-2018, 09:39 AM
Update
So of course the autopilot now appears to be working perfectly (as it was for months previously).
If I just leave a microSD card in the slot, will it continue to log data (and overwrite old data) so that I can catch it in the act if it does it again?
Somewhat related question: is it possible for my setup to generate an audible warning when the autopilot disconnects? The flashing yellow AP can be easy to miss, since the G5 is not my primary attitude indicator display.
DMG
N929JA, 2007 RV-9A
2020 Dues Paid
06-14-2018, 09:55 AM
Super Moderator
Why?
Why would the autotrim decide to be reversed when it has been working correctly for so long?
Vic
 Vic Syracuse
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
06-14-2018, 10:50 AM
Vic
Also my conclusion. I don't think there's anything wrong with the autotrim setup.
And per Garmin above, the autopilot doesn't give up and disconnect due to out-of-trim conditions in any event. But I can confirm that in both of my recent losses of the autopilot function, it first trimmed the ailerons all the way to the right.
N929JA, 2007 RV-9A
2020 Dues Paid
