POSTING RULES
Donate yearly (please).
Advertise in here!
Today's Posts
Insert Pics
03-05-2007, 06:26 AM
XP-IO-360 vertical draft install references?
Hi Guys,
I am looking for people and reference websites that have successfuly installed a XP-IO-360 vertical draft FI in a RV7 or RV9.
I am currently busy with mine and are constantly running into small items I wish I could see how others have resolved it.
Thank you in advance.
Kind Regards.
Rudi
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
03-05-2007, 09:18 AM
Good morning, Rudi.
My -7A has the same engine with the SilverHawk EX FI system.
The biggest problems I've had so far are:
* The mixture arm swings downward which interferes with the airbox. I didn't know it at the time, but Precision Airmotive sells a servo with the arm reversed which eliminates this problem. You can't simply rotate the arm 180 degrees on the servo because the throw will be in the wrong direction. I know that some folks, including Scott Will have used a quadrant instead of venier cables which apparently eliminates this problem. I am modifying the FAB with a cutout to allow the mixture arm to swing downward.
* Prop Governor -- If you're installing a C/S prop and using the Van's-provided governor you'll need to rotate the arm around. This isn't specific for the XP-360 though as I believe pretty much everyone has to do this these days.
* Oil Output Fitting for the oil cooler. All I can say is holy #$%@! I spent more than two hours last night putting this thing on (45 degree fitting). I had to pull the right mag to do it. I'll need to recheck my timing before first engine start -- oh well. I would recommend people install this fitting before they hang the engine if they can. Better yet...I would call your engine builder and ask them if they can install it for you before they mount all of the accessories.
* Metered fuel line (servo to flow divider hose) has to go through the rear baffles and is close to the oil cooler if you're mounting the cooler on the baffles. I did put my cooler on the baffles and I think I can get the hose through there but it's going to be a challenge. I don't know if the Superior-supplied hose is going to work.
You can check out my stuff at my website (see signature). Please keep in touch. I have a LOT of questions myself about this stuff.
"What kind of man would live where there is no daring? I don't believe in taking foolish chances but nothing can be accomplished without taking any chance at all." - Charles A. Lindbergh
Jamie | RV-7A First Flight: 7/27/2007 (Sold)
03-06-2007, 10:45 PM
Hi Jamie Thanks,
Luckily got th right Fuel Servo with to correct arm, but then the XP supplied fuel hose don't fit from pump to servo. So I had one made up.
I see the supplied hose from servo to FI spyder currently fits, but will see when I fit the oil cooler and baffles. I hope I don't have to make another hose.
PS: Keep in touch, let me know what you find as you go along.
Any other refernces please add below.
Kind Regards
Rudi
03-07-2007, 03:59 AM
Nothing to add except..
I have the SJ cowl, otherwise the same. I left the oil filter straight 90 degrees to engine. Write for phone number if you like; I'm retired and can take daytime calls.
H. Evan's RV-7A N17HH 240+ hours
"We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
03-07-2007, 08:09 AM
Originally Posted by RudiGreyling
Hi Guys,
Kind Regards.
Rudi
If you have the Silverhawk, be aware that you can bring your pressure hose out of the front, or the back. It is much easier to come out of the back, up through the back baffle, and then to the distributor than trying to snake around the front especially if you have cross over exhaust.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
03-08-2007, 06:57 PM
Originally Posted by Jamie
* The mixture arm swings downward which interferes with the airbox. I didn't know it at the time, but Precision Airmotive sells a servo with the arm reversed which eliminates this problem. You can't simply rotate the arm 180 degrees on the servo because the throw will be in the wrong direction. Please keep in touch. I have a LOT of questions myself about this stuff.
Is anyone aware of any builder who has actually purchased a Precision Silverhawk servo with the reversed arm as mentioned above and proved that it works OK with the vertical induction set-up.
Perhaps some-one can refer me to an RV website.
I'm very interested in this but I can't tell if it's a good idea or not.
You’re only as good as your last landing
Bob Barrow
RV7A
03-09-2007, 08:04 AM
Yes - I have that setup on my 6. I had clearance issues with the side of the cowl scoop but modified the mixture arm to make it work. It is very doable.
Bucker Jungmann
RV1 - Proud Pilot.
03-09-2007, 09:00 AM
My TMX-I/O360 has the Silverhawk and to cure the problem of the arm hitting the FAB I made a 1" spacer using a commercial grade cutting board that is chemical & heat resistant. It goes between the bottom of the throttle body and the FAB and will give the clearance needed for the mixture arm. Simple and took only an hour to make.
I'll post some pics over the weekend if anyone is interested.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
03-09-2007, 01:14 PM
Please do!
Jekyll
03-09-2007, 01:53 PM
You must have the standard mixture control, not the reversed mixture control. The reverse mixture arm points up. This allows you to use the standard carb bracket from vans.
Bucker Jungmann
RV1 - Proud Pilot.
