Old 02-03-2018, 09:10 AM
DennisRhodes DennisRhodes is offline
Default MOAs and activity
Anyone know of a good web link for MOAs to determine if they are active or not? Possibly a schedule of activity upcoming? Something other than FF or FSS at the time when the MOA is approached. DRR
DRRhodes
2020 VAF Supporter
RV9 N908DR
Old 02-03-2018, 09:20 AM
az_gila's Avatar
az_gila az_gila is offline
The FAA SUA graphical web site is pretty good, and gives active times -
https://sua.faa.gov/sua/siteFrame.app
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-03-2018, 11:29 AM
Lenny Iszak's Avatar
Lenny Iszak Lenny Iszak is offline
SUA status is also included in ADSB broadcasts, just don't know any device that can display it.
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 650 hrs
OnSpeed development team
Old 02-03-2018, 12:11 PM
turbosaaber turbosaaber is offline
Default Not always
I work at Miami artcc and we have a lot of unscheduled activations of special use airspace. Best to check with us just to be sure.
Carl Bridges
RV7 N278RV
NOW FLYING
Old 02-03-2018, 02:59 PM
Plummit's Avatar
Plummit Plummit is offline
Uh, if it can't be displayed, how do you know it's included? Just curious.
~Marc
N814RV
2020 Donation Made
Old 02-03-2018, 03:22 PM
YellowJacket RV9 YellowJacket RV9 is offline
~Marc
https://www.faa.gov/nextgen/programs/adsb/pilot/#fisb
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 02-03-2018, 03:40 PM
I've never paid any attention to the MOA blocks to see if they change colors with ADSB IN reporting. ?? The above Nex Gen site seems to say that SUA s are included! I have notices a TFR that was NOT included in one of the KATL area broadcast about 6 months ago!!
DRRhodes
2020 VAF Supporter
RV9 N908DR
Old 02-03-2018, 08:07 PM
ryan ryan is offline
And on the other side of the same coin, special use airspace will often be under NOTAM due to being scheduled, but it won't actually be active at the time that you're wanting to pass through it. Many MOAs aren't active until military aircraft are approaching and asking the controlling agency to activate them, and then they're cold again as soon as the military aircraft leave. So it's still worth asking about the status even if you see a NOTAM or posted hours, it might save time and gas if you're inclined to go the long way around.
Controllers understand our concern with efficiency. Unless there is way to get accurate real-time updates displayed, talking to them is the way to go.
Columbus, Ohio
1994 RV-4 - Previously flying, currently updating
1967 PA-28-140/160
Old 05-09-2020, 11:00 PM
It would be nice if on a Dynon Skyview, when you touch the MOA on the screen that at least a radio frequency comes up to enter, so that you can check in for current activity, and at least put on an Ident frequency so they can at least see the area you are in.
Old 05-10-2020, 09:45 AM
donaziza's Avatar
donaziza donaziza is offline
I've got an old Garmin 496. It has all the ATC center freqs on it wherever you happen to be. If I want to go thru a MOA, I just call center and ask them if its hot or not. I know some guys just plow right thru them, and never ask. There was an F-16 that ran over a small aircraft in South Carolina--maybe a year ago.The F-16 guy had an ejection seat. The small airplane did not. You get the picture. Learned this trick from Ron Shreck. I think everyone here pretty much knows who Ron is.
