Go Back   VAF Forums > Main > RV Building Tips/Techniques
Old 10-18-2017, 05:37 PM
Bavafa Bavafa is offline
Default Cleaveland main squeezer usage/report
Just wondering if there is a trick in using the main squeezer, I bought one and still getting used to it but not very impressed so far. My main issue is that I feel a rather strong springy action in the lever. Best I can describe it, if the squeezer is held with the handles at 12:00 and wide open action would be at 3:00, you will start feeling the pressure building up between 2:00 to 1:00 and then eases off as the handle is coming together at 12:00. But as soon as I want to open it, the handle wants to jump (spring action) to open position which kicks the other handle to opposite side (let?s say 11:00) and this can cause my piece that is still between the yoke to bend if I am not careful.
Not sure if this was a good way of explaining it but I wonder if mine is defective or all work like that?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 10-18-2017, 06:41 PM
Neal Trombley Neal Trombley is offline
I love mine.
You may have your dies too close together what do you rivets look like? My guess is just some Simple adjustments or call Cleveland and have them help you out they’re a great company and the tool is well worth it
Neal Trombley
SW Florida
EAA 66
N517NC ( reserved)
Dues Paid
NOV 2016
July 2017
Dec 2017
Old 10-18-2017, 07:31 PM
Nihon_Ni's Avatar
Nihon_Ni Nihon_Ni is offline
Default I love mine too!
There is always going to be a little spring back after you squeeze a rivet, because the rivet resists deforming into the shop head that you are performing. My technique is to hold the non-moving handle firmly against the part, with the rivet's manufactured head facing the handles, then rotate the movable handle up to meet the non-moving handle, then (while still holding pressure on the non-moving handle) release the moving handle until the pressure is released. Another tip is to have the part you are riveting secured to something (like a workbench) so it won't move around on you while you are riveting. I have a bunch of clamps that I use to hold small pieces to my bench for riveting. Keep practicing on scrap until you have the technique down. Once you get the hang of the Main Squeeze, you'll be able to tell by feel if a rivet has been squeezed enough or not.
Rob K
RV-8 N884RA under construction
Old 10-18-2017, 07:36 PM
bret's Avatar
bret bret is offline
when I first started my project, I did not know that the moving die shaft is adjustable by screwing it in or out
Old 10-18-2017, 08:12 PM
rv9builder rv9builder is offline
Mine feels pretty similar to what you're describing, so I don't think yours is defective. Work with it a bit longer and you'll get used to it. If you've ever tried to set 1/8-inch rivets with any other squeezer, you'll quickly realize how great the Main Squeeze is, and the characteristic you're describing is a pretty minor inconvenience.
Rob?s tip is a good one to keep the work clamped if possible, especially in the beginning when you're first getting used to using the Main Squeeze.
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
Old 10-18-2017, 08:16 PM
rapid_ascent rapid_ascent is offline
I don't love mine. I tend to use it only when I don't seem to have anything else that will work. It's a usable tool but I prefer other options.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 10-18-2017, 08:29 PM
Make sure it doesn?t extend more than 1 inch or you can break the Main Squeeze.
Fortunately, Cleaveland was able to fix mine!
There are some instructions in a PDF file on the Cleaveland website on how to adjust it correctly.
http://www.cleavelandtool.com/Main-S.../#.WegKvK3MxE4
RV-12iS Fuselage
RV-9A Project: Sold
Old 10-18-2017, 08:32 PM
Thank you every one for the tip and experience. I am on my second RV, so I have used squeezers before and some what familiar with the technic. I use the same technic as Rob when is possible and have learned to use my chin to control the non-moving handle during the release but it is not convenient or always possible. This issue is more acute when dealing with softer parts like the flange of a rib.
I am not very impressed and have gone back to my older squeezer on those fragile parts.
Thank you for your feedback.
Mehrdad
Dues paid
Old 10-19-2017, 04:07 AM
rzbill's Avatar
rzbill rzbill is offline
When I started my build, I considered a main squeeze. I recognized the physics tradeoff of more handle travel needed to get less hand grip squeezing force. It is an individual choice or preference concerning the use of a hand squeezer so I understand the popularity. I chose to not go that way. I valued the ability to 'one hand' a small rivet more than the ease of squeezing a large rivet with two.
Bill Pendergrass
ME/AE '82
RV-7A: Flying since April 15, 2012. 850 hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'... Eyeballin' vinyl really hard.
Yeah. The boss got a Silhouette Cameo 4 Xmas 2019.
Old 10-19-2017, 08:12 AM
9GT's Avatar
9GT 9GT is offline
When I first started acquiring tool to build my RV-10, I opted for the cheaper Main Squeeze. After a couple first rivets, I set it down and ordered a nice pneumatic squeezer. I must say, it was the best decision I ever made in regards to an expensive tool purchase.
David C.
Howell, MI
RV-10: #41686 Under Construction
RV-9A: #90949 Under Construction
RV-10: #40637 Completed/Sold 2016
Cozy MKIV:#656 Completed/Sold 2007
"Donor Exempt" but donated through Dec. 2020
