Old 09-28-2017, 11:59 AM
Default RV14 detail 5
This is a shot of the forward upper gear leg faring. It has been recessed into the cowling to make a smooth transition between the cowling and the upper gear faring
https://photos.smugmug.com/My-First-...MG_6435-X3.jpg
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
Old 09-28-2017, 01:20 PM
Jared_Solomon's Avatar
Jared_Solomon Jared_Solomon is offline
Default Beautiful
That is some beautiful glass work! Kudos to you!
Jared Solomon
A&P, EAA Technical Counselor
Powder Springs, GA
2020 Dues Paid
RV-14A (N214WJ) - Flying since Sept 2017
RV-7A (N211WJ) Flying since 2009 (SOLD)
RV-7A (N132RD) bought flying 2014 (SOLD)
KPUJ (Silver Comet Field)
Youtube channel: http://www.youtube.com/jmsolomon2000
RV-14 Build Log: http://rv14.jaredsolomon.net
Old 09-28-2017, 01:29 PM
Driving '67 Driving '67 is offline
Very nice Tom! Any word on the flight permit?
Cheers Jim
RV 14A wing/tail/fuselage done
Canopy time
Serial 140118
Donation 2018/19
Old 09-28-2017, 01:45 PM
Still waiting, it has been two weeks since inspection!
CPL & IFR rated
RV14 Tail dragger
Fairlea Field
Old 10-10-2017, 11:58 AM
czechsix's Avatar
czechsix czechsix is offline
Did you just use micro to do the build-up, or something else?
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 10-10-2017, 02:21 PM
1. remove gel coat from cowling, one to two inches away from the faring
2. use a stiff mixture or flox and epoxy to build up the area around faring
3. One layer of glass cloth over the flox mix
4. peel ply
When dry sand smooth and apply thin layer of micro to fill gaps, depressions etc.
Micro is pretty tough but it is not structural and can crack if it is too thick.
This is a small job that cleans up the upper farings much the same as the plans call for on the lower gear faring/wheel pant intersection.
There are probably a million ways to do this small job but it is a nice finishing touch. On my rocket I extended it aft over the metal of the forward fuselage.
On the RV14 the faring tucks back under the fuselage and there was no real benefit from a drag perspective to continue the build up onto the metal.
NOTE; this job is really easy if you do it after the upper faring are completely finished and the screws in place on the cowling. Take cowling off aircraft, turn it upside down and then screw the faring in place using the three common screw holes. This makes sanding really easy and keeps the sand paper away from the metal bits.
CPL & IFR rated
RV14 Tail dragger
Fairlea Field
Old 06-30-2020, 03:51 PM
cjs cjs is offline
Tom,
I tried to see the picture you posted on this, but it appears the link has expired. Could you post it again?
Craig
