Old 05-14-2017, 09:37 PM
Plummit's Avatar
Plummit Plummit is offline
Default IO-540 oil drain
I have a BPE IO-540 with the AFP fuel injection system. The oil drain has a Tee that connects a hose from a little higher point on the back of the engine. The bottom of the Tee has a B nut that must be removed to drain the oil. Why is the Tee necessary and is there a better way to drain the oil?
~Marc
N814RV
2020 Donation Made
Old 05-15-2017, 04:55 AM
Auburntsts's Avatar
Auburntsts Auburntsts is online now
Something is not right. The oil drain should be on the bottom left side of the sump not on the back of the engine. I've got the same engine and FI from BPE and no tee. Got a pic?
Todd ?I drink and know things? Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 05-15-2017, 05:43 AM
Jesse's Avatar
Jesse Jesse is offline
Call BPE and ask Allen.
Jesse Saint
Old 05-15-2017, 06:03 AM
Default Do you have the cold air induction?
there is no internal oil pickup in that sump. You need to run a 10D line from the Tee to the upper fitting. The 10D hose has a bend radius of about 5 1/2" so the hose ends up being longer than you would expect...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 05-15-2017, 08:26 AM
Plummit's Avatar
Yup, that's what Allen said. It seems that when you use a horizontal injection system there is no pick up for the oil so they install a Tee fitting then a B nut for the oil drain.
It's a bit of a problem holding the Tee while breaking the B nut loose. I was told that someone makes a quick drain fitting that will work with the Tee?
BTW, a shout out to Barret: They saw my post and figured I'd be calling. Good to know they follow VAF!
~Marc
N814RV
2020 Donation Made
Old 05-15-2017, 09:40 AM
Default Try
Try saf-air for the drain....
Bob
297 HP Barrett Hung
Wiring...
Old 06-11-2017, 03:57 PM
Plummit's Avatar
I didn't see anything on the Saf Air website. Everything they show has male threads.
-Marc
N814RV
2020 Donation Made
Old 06-11-2017, 06:49 PM
Default On my list
On my list to call them. Someone on this forum said they have made one but wit didn't make it online yet. I will call them and see tomorrow. Will post answer here...
Bob
297 HP Barrett Hung
Wiring...
Old 09-06-2017, 04:00 PM
MikeAllen MikeAllen is offline
I've just discovered I have the same oil drain problem on my BPE narrow deck engine. Allen confirmed the Saf-Air Products P5000 oil drain valve won't fit the Tee. I don't fancy the idea of going back to wrestling a B nut off a hot Tee fitting and covering my hands in hot oil.
Has anyone found a better solution that keeps a Tee for the for the hose to provide the oil pickup but takes a different quick drain valve? Is there a quick drain fitting to simply swap out the B nut?
Mike
Old 09-06-2017, 07:44 PM
Plummit's Avatar
Default I still haven't found a quick drain
Hot oil isn't the problem that I have, it's that the whole Tee turns when trying to get the B nut loose. Of course I use a back-up wrench on the tee, but it's impossible to hold it perfectly still.
-Marc
N814RV
2020 Donation Made
