POSTING RULES
Donate yearly (please).
Advertise in here!
Today's Posts
Insert Pics
02-02-2019, 10:43 PM
Well now that the flaps are done I decided to do the aileron and elevator push rods. First I had to take a couple of weeks off for this bundle of joy. Say hello to my new aviator named Avden with his custom RV hat.
20190123_151619 by Jereme Carne, on Flickr
After getting the push tubes cut to length I needed to sand down both ends of the large elevator push tube as it was a tight fit. Chucking it into a drill was the easiest way with a sacrificial bolt.
20190120_155358 by Jereme Carne, on Flickr
Next it was off to the races with the drill press. I started with a #41 and then a 1/8" bit.
20190202_161019 by Jereme Carne, on Flickr
20190202_171740 by Jereme Carne, on Flickr
The dining room table has been taken over again for a little deburring. Hopefully tomorrow I will get to prime the inside of the tubes and maybe outside if I find the time.
20190202_223441 by Jereme Carne, on Flickr
Good to be working on the plane again after about a two week break.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
02-03-2019, 08:38 AM
Again, congratulations Jereme!
Work still chugging along for the machine! Awesome.
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Reason: (SP)
02-04-2019, 09:30 PM
Thanks man!
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
02-17-2019, 09:59 PM
Slow going the past couple of weeks but still making progress. Finished up the pushtubes just in time for a bunch of family visits to see the new little one. I also started working on the FlyLEDs kit, pics coming soon.
20190206_183109 by Jereme Carne, on Flickr
20190217_070442 by Jereme Carne, on Flickr
20190215_161806 by Jereme Carne, on Flickr
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
02-21-2019, 07:59 PM
Decided to assembly the FlyLEDs kit I received last year, I have been saving it for cold weather. This was one of the funnest parts of the build so far! I don't solder as much as I would like so this was a treat.
Here are the blank boards before trimming the main boards to fit the wingtip. An oscillating orbital sander made this trimming so easy it wasn't even fair.
20190217_160648 by Jereme Carne, on Flickr
Started by putting the strobe LEDs on the boards.
20190217_170547 by Jereme Carne, on Flickr
Next the small position LEDs were installed.
20190217_174527 by Jereme Carne, on Flickr
The large resistors were then installed.
20190217_205115 by Jereme Carne, on Flickr
Finally after bending the correct angle I soldered on the connector, this is different than if you had the full board kit, I'm doing skinny boards so I can install some squadrons as landing lights. (purchased before they came out with landing light option)
20190217_211046 by Jereme Carne, on Flickr
Next it was onto the control board. Started with resistors as per the instructions.
20190218_184532 by Jereme Carne, on Flickr
Then onto some various parts.
20190218_190230 by Jereme Carne, on Flickr
The last little pieces were soldered.
20190218_212811 by Jereme Carne, on Flickr
You can use a 9V battery to test everything and play around with what strobe pattern you want. I highly recommend this kit to anyone that wants some good lights at a great price and wants some fun in building!
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
02-25-2019, 11:44 AM
I drilled my mounting holes too close to the internal circuit board and shorted out several LED?s. Paul at Flyleds responded almost immediately to my email and helped me troubleshoot the issue. He sent me two new LED?s and a few spares. Customer service is top notch.
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
02-25-2019, 03:30 PM
Jereme,
Are you installing landing lights in the wing tips? Are those short boards for landing light clearance? That reminds me of assembler days at an engineering firm I worked at in Calabasas CA. Watching the crew do surface mount work, tiny tiny.
Great work!
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
02-26-2019, 06:52 AM
Thanks for posting, so many people have good experiences with Paul that it was a no brainer where I decided to spend my money.
Jereme,
Great work!
Yes I'm installing some Squadron Pro lights in the wingtips which is exactly what the short boards are for. FlyLEDs now makes one with the landing light option built in but I had already purchased the lights I have so no biggy.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
02-27-2019, 11:22 AM
Thanks, Carne! I couldn't find the order tab for what you have. Will spend more time today on it.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
03-10-2019, 09:51 PM
Well the weather has finally turned into a Wyoming springtime (30s) which means it's time to go full steam again in the garage! I'm looking forward to a productive work year, perhaps so good that I'll be flying at the end of it!
The firewall insulation has been on my mind lately so I decided to just tackle it and get it done. First I went through and drilled a hole mess of holes in the firewall for various things. I ordered in a piece 0.010" titanium from TMS Titanium, this was quite honestly cheaper than the titanium foil some people use and I simply don't like the look of the wrinkly stainless. I'm not done yet but I am glad I went this route, it seems very sturdy and when it gets riveted/bolted down I don't think there is going to be very much wrinkling.
First I cut the sheet on a foot shear. Cutting the sheet is for letting the fibrax below a path for off gassing in the event of an engine fire. Next simply trim them to fit on the firewall.
20190310_130421 by Jereme Carne, on Flickr
20190310_153150 by Jereme Carne, on Flickr
No you start marking the holes on the titanium from the backside. I then took off the sheets and went to town with a drill and this little guy (worth every penny of the $24.95 I spent on it).
20181103_143607 by Jereme Carne, on Flickr
20190310_160209 by Jereme Carne, on Flickr
20190310_173907 by Jereme Carne, on Flickr
I still have a few holes to finish cutting out of the titanium and after that I will start working with the fibrax. That's all for today though.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
