Old 02-20-2017, 06:57 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Default SDS Dual ECU Wiring
In the past we've not posted a recommended schematic for wiring the components of our EFI systems in aircraft as it seemed everyone had their own preferences and ideas. Now, we're receiving more calls for recommendations so here's a schematic which some may find useful.
Notice there are two independent batteries and a fuse/ breaker/ switch for each fuel pump. There are also separate grounds for each device and separate switches for each important component.
There are no diodes.
There are no unfused main power wires feeding the essential bus.
We never recommend stacking grounds.
We never recommend critical components be tied to other component power switches or grounds as this does not promote redundancy.
Pilot intervention is required for all switching. You may run both pumps at low altitude.
Both ECUs are always powered. Each ECU is always running one set of 4 plugs. We only switch the injector outputs and relay default (closed contacts, no power required to them) has the primary ECU running the injectors.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 08-29-2017, 08:42 AM
Chkaharyer99 Chkaharyer99 is offline
Ross,
Do you have a wiring diagram for Dual CPI's and Dual batteries? I've seen it before but can't seem to located it now.
My email is my screen name followed by @yahoo.com
Thank you
Charlie
RV-8
Old 08-29-2017, 08:55 AM
Originally Posted by Chkaharyer99 View Post
Ross,
Thank you
Ross,
Disregard. I found it. Thank you.
Charlie
RV-8
