Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Electrical Systems
Old 02-16-2017, 06:38 PM
TXFlyGuy TXFlyGuy is offline
Default EFII Bus Manager
How many here are flying with the EFII Bus Manager? It looks pretty good, and actually is similar in some ways to the auto-bus tie switching we have on Boeings.
I contacted the company, and their claim was they have never experienced a failure of the bus manager.
What is your experience?
http://www.flyefii.com/products/bus-managaer/
Old 02-16-2017, 07:00 PM
If you have an electrically dependent a/c (engine, and/or, if IFR capable, panel), get an actual schematic of the box's guts & analyze failure modes.
There was an extensive discussion on the Aeroelectric list recently.
Old 02-17-2017, 06:57 AM
The company claims no failures. It does have an emergency selector to manually select a battery to power the essential bus in the event of a failure.
No one here flying with this?
Old 02-17-2017, 07:01 AM
See my previous post.
Old 02-17-2017, 07:20 AM
jcaplins's Avatar
jcaplins jcaplins is online now
I have one; and my -7 requires electrons to keep the engine running.
I had a problem with the Fuel pump switch-over circuitry during the initial testing after install. The problem was was taken care of perfectly by EFII.
I'm happy with it and if I could make any changes, it would be to add an "off" positions to the fuel pumps. (as it stands you can only switch between "1/auto" and "2".) I may add something to the switch/relay circuit sometime in the future to take care of that.
Jeff Caplins
California
RV7 N76CX
(started: Feb 2002 --> Completed: May 2016)
Old 02-17-2017, 08:42 AM
Thanks. Our flight testing is a few months down the road. Good to hear that EFII gave you good support.
Old 02-17-2017, 09:22 AM
Fred.Stucklen's Avatar
Fred.Stucklen Fred.Stucklen is offline
Default Buss Manager Concept
I've essentially installed my own design of this concept, and for a LOT less $$$. My aux fuel pump has OFF - AUTO - ON selection modes.
Fred Stucklen
wstucklen1@cox.net
RV-7A N924RV Flying (1825 Hrs & counting)
RV-6A N926RV 875 Hrs (Sold)
RV-6A N925RV 2008 Hrs (Sold)
Old 02-17-2017, 02:24 PM
bret's Avatar
bret bret is offline
Dual EFII, I went with all manual high quality switches, my HDX will alert me if fuel pressure or volts get low, then I just confirm and flip a switch, BU pump, ECM, or battery. KISS!
Old 02-17-2017, 04:56 PM
johnbright's Avatar
johnbright johnbright is offline
Default EFII wiring
I would leave out the Bus Manager. EFII provides only a simplified schematic and no mention of FMEA. Bus Manager could be OK but "we never had a failure" is not an answer; for instance, you could fly 1,000 hours with a single magneto and say that.
Would you wire the fuel pumps the way EFII suggests with shared wires, breaker, and relay?
http://www.flyefii.com/media/Bus_Man...structions.pdf
John Bright, RV-6A 25088, N1921R reserved, at FWF
O-360, 8.5:1, vert sump, dual SDSEFI EM-5-F
Schematic and other electrical related files
Instrument panel CAD jpg images
Construction Photos
Newport News, Va
Old 02-17-2017, 04:57 PM
johnbright's Avatar
Default Aeroelectric LIst EFII discussion
rv7charlie... do refer to this thread? I don't necessarily read all the responses but I do read all that come from nuckolls.bob
Construction Photos
Newport News, Va
