Old 11-23-2015, 02:22 PM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Default F-00081 / F-00083 Question
I can't find the section which covers the preparation (dimpling, ev. drilling) of the ADAHRS-Baggage Floor (F-00081) and Baggage Cover (F-00083).
I have gone through the revisions at Van's web-page but didn't find any sections regarding those two parts.
Even though I am not yet at that point, I would like to have them prepared in advance for priming and painting among other interior parts.
There's probably not much to do with those two parts but I want to avoid drilling and dimpling them once they are primed/painted.
So if anybody can point me in the right direction, that would be much appreciated.
Thank you!!
Chris, RV-12 S/N 120832, HB-YSC
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2020
Old 11-23-2015, 04:17 PM
Rick_A's Avatar
Rick_A Rick_A is offline
As best I recall, the ADAHRS cover is in the Garmin installation section. If you haven't ordered your avionics yet, you may not have it. I think the other half cover is in that section also.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 11-24-2015, 12:10 AM
Thanks Rick. That makes perfect sense.
I haven't reached the avionics section yet. I ordered those parts together with the split baggage bulkhead for easier accessibility/maintenance in the future, so that the tank does not get in the way.
Old 11-15-2019, 06:39 PM
AeroDog AeroDog is offline
Thank you!!
I have the Skyview so won't have the ADAHRS under the floorboard, but I was advised by the Mothership to get the two-piece setup to provide access to the stuff under the floor without removing the tank. Not only can I not find any instructions for installing these pieces (maybe it comes with the Skyview avionics kit) but I can't find any mention in the KAI of installing the original piece of the baggage compartment floor covering. Obviously this needs to be installed before the final tank install. Any help will be appreciated.
Jerre
Empennage, fuselage and wing kits complete
Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2020
Old 11-15-2019, 07:51 PM
Vakashi Vakashi is offline
Assuming that you are building an RV-12 not an RV-12is, my F-00081 and F-00083 were supplied with my SkyView kit. The floor panels are referred to on page 42C-11, which is downloadable from Van's service information and revisions page. Look for 19 April 2016.
I think that you will unlikely be final installing your fuel tank before installing all the avionics aft of the baggage bulkhead, as you will need the full opening width for access, unless you install that lot before attaching the tailcone (which is what I did), but even then you need to be able to reach the aft pitot tube and wiring to fasten them to the J-stiffeners anyway.
Of course you could spend an extra $15.40 plus p&p and buy F-00081 and F-00083 from Van's store if you want to paint them now.
Old 11-15-2019, 09:47 PM
rolick22's Avatar
rolick22 rolick22 is offline
Hope this helps
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Phase I Finished on 5/7/2020
Need:
Paint?
Serial#12-0864
N112DR
VAF donation made for 2020
Old 11-16-2019, 11:32 AM
Thanks guys. I am building the -12 not the -12iS and I was going to final install the tank while waiting to purchase the avionics kit, though I'll now wait if you guys think it's prudent. I did go ahead and buy the F-00081 and F-00083 erroneously assuming they wouldn't come with anything related to Skyview. I'm still baffled by the all the holes in those parts, but I suppose all will be revealed in time.
Jerre
Old 11-17-2019, 02:06 AM
If you are going SkyView, nine of those holes will be filled in with rivets. They are not used.
