Old 11-02-2014, 07:41 AM
Elwell81 Elwell81 is offline
Default G3X touch panel installation
Just got everything installed for the final time! Looking forward to getting the plane done so I can use all of this stuff.
Old 11-02-2014, 07:47 AM
Brantel's Avatar
Brantel Brantel is offline
Very nice! Looks great! You will love it!
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Project Sold
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-02-2014, 09:17 AM
gfb gfb is offline
Almost exactly what I'm playing around with. Would you mind posting some more detailed pics? How did the install go?
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
Old 11-02-2014, 02:19 PM
Default Closer Pictures
http://i1293.photobucket.com/albums/...ps0mfxo2gk.jpg
http://i1293.photobucket.com/albums/...psjdltgrwm.jpg
Here are a couple closer pics. My system includes the following:
G3X touch PFD and MFD
PMA8000BT audio panel
GTN-650
GMC-305 AP controller
Roll and Pitch GSA-28's
Dual ADHARS
GTR-20 remote com
GTX-23ES remote transponder
VP-X Pro
Aero 455 pulse oximeter/CO monitor
It was very straight forward to install, I had Steinair draw up a schematic when I bought all of the components. The hardest thing for me was deciding where to mount things behind the panel and also behind the baggage bulkhead. I see you are in Madison, your more than welcome to come up to Green Bay and have a look.
Let me know if you have any more questions
Old 11-03-2014, 05:57 AM
gfb gfb is offline
Thanks, I might take you up on that.
Do you have a backup/emergency bus? How did you lay it out?
Dual magnetometer? I/m curious what functionality we loose if the magnetometer goes out.
Old 11-03-2014, 07:29 AM
Zac@AerosportProducts Zac@AerosportProducts is offline
That looks great!! Very clean.
Zac Holcomb
Future builder of something, someday.
I live it through all of you. Thanks!
Zac@AerosportProducts.com
3DPrint@AerosportModeling.com
Old 11-03-2014, 07:45 AM
BillFear BillFear is offline
Default Wow!
One of the cleanest I have ever seen. congratulations! Love the GRT mini as the backup.
Bill Fearheiley
Lake Norman, NC (14A)
RV7a N705RP (no longer own)
Contribution in for 2017, money well spent
Old 11-03-2014, 04:18 PM
Default Thanks for the compliments
I have the TCW backup battery (6 amp hour if I recall), wired as shown in the G3X install manual. It connects to the secondary power inputs for the PFD, MFD, GEA 24 and a GSU 25. My plan is to switch on the emergency buss for engine start (Avionic switch off) and leave it on for the entire flight. With the input to the TCW programmed (from VP-X) to turn on with the avionics switch, the TCW outputs will be shut off once it sees sufficient primary battery voltage and will only turn back on in a low voltage scenario. Here is a picture of where I mounted it.
I only have a single magnetometer, that's one reason for the Mini-B as backup. I haven't calibrated the magnetometer yet and the only thing I see missing is a heading reading (red X), there may be other things missing as well. The G3X manual is pretty good about explaining what sensors/inputs are required for certain functions.
Old 11-03-2014, 05:20 PM
Default GMU-22 Install location?
I am installing my G3X system and appreciate the photos you have of your install. I have a request for a photo of how and where you installed your GMU-22 magnetometer. My panel was just delivered last Thursday and while I am out of town, I am trying to layout my install. Your photos are a great help. Thanks
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 11-03-2014, 06:08 PM
Default No Picture right now
Sorry, I just left for work today and won't get back until the 17th of December.
I would be more than happy to get a picture when I get back but its a pretty easy explanation. Basically in the aft deck under the fairing, its the recommended location on page A-3 of the G3X install manual.
Here is where I put the rest of my components.
