Old 08-14-2014, 02:48 PM
donaziza's Avatar
donaziza donaziza is offline
Thumbs up Bailing out of an RV-8 especially if you're on fire
I've started a couple of threads on this subject in the last 7 years. Got various answers on how one couldn't open the canopy in flight on an RV 8 due to high/low?? pressure. Paul Dye, years ago, suggested I put easy to remove "pip Pins" in the front of the canopy, where there are presently bolts with nuts. Or even to take off with them not installed at all, (the forward windscreen metal hoop would hold the canopy in place. (This I did with my old 8, and it worked fine even during acrobatics)
I had also asked Vans if they had any documentation on anyone ever bailing out of an RV 8. They said "yes", but unfortunately, the poor guy didn't have a parachute. (Obviously a fire, else why would he have done it)
So here's my question: I'd like to write Vans and see if they would be willing to sacrifice an 8 to see if one can indeed get out of the thing if one had a rip roaring fire. If one uses the "pip pins" as per Paul Dye, I'm assuming you'd only have to slide the canopy back a half inch or so, push up, and bang, that canopy is gone. Would it hurt the vertical stabilizer?? Sure, probably,---- probably put a nice dent in the upper forward leading edge of the VS, but who cares, you're leaving anyhow. Maybe there is something Vans could do in a wind tunnel test vs a real airplane.
So now the point of all this. If I'm the only one to write Vans, I think I'd probably be dismissed as "Yeah Right". But if a whole lot of us write, maybe 50 guys or so, I would think we'd have their attention. I only know RV 8's, but I would think my thinking would apply to any slider canopy, ie RV 6's etc. ( Don't know how one would deal with the "tip up" canopies.
Whadaya'all think of my idea?
Old 08-14-2014, 02:52 PM
sailvi767 sailvi767 is offline
I may not quite understand what you want but what happens to the pilot in this test?
George
Old 08-14-2014, 02:59 PM
donaziza's Avatar
George
Of course I wouldn't want anything to happen to a test pilot----that's a given. -----Vans would have to engineer it where the test pilot gets out no matter what. (I.m no aeronautical engineer---is this not possible?
Old 08-14-2014, 03:02 PM
XOverZero's Avatar
XOverZero XOverZero is offline
I see lawyers....
John Halcrow
Tustin, CA
RV-12 120682
Emp/TC done; Wings done; Fuse kit done
"History teaches us that men and nations behave wisely once they have exhausted all other alternatives." --Abba Eban
Paid up until Aug 2021
Old 08-14-2014, 03:05 PM
donaziza's Avatar
Originally Posted by XOverZero View Post
I see lawyers....
Well, Could it be done in a wind tunnel test??
Old 08-14-2014, 03:15 PM
N941WR's Avatar
N941WR N941WR is offline
I see lawyers....
That is funny!
If the canopy comes off cleanly, the pilot can land the plane. Someone will still need to pick up the pieces. (It has been reported that -8's fly fine w/o the canopy.)
If it hits the VS or HS, the pilot (Joe Blank?) is going over the side, then IF the plane doesn't hit anyone/anything, Van's will have a mess to clean up. The environmentalists will go crazy due to the spilled oil and 100LL. Oh, that leaded fuel will be a BIG issue.
I don't see it happening because I'm not sure the certified manufacturers have done the same test.
Good luck, I think the results would be interesting. BTW, I would think they would run this test on a SbS simply because there are more 6, 7, 9, and now 14's than 8's.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-14-2014, 03:18 PM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Ummmm. Yeah, you're going to get a "yeah right" even if 50 folks write.
To sacrifice an aircraft and put a pilot at risk for such an answer is not realistic.
This the experimental/amateur built market we play in. It's not like they're selling certificated aircraft here with airframe parachutes that need to be proven.
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 08-14-2014, 03:26 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Someone has already proved that you can indeed open the canopy of an RV-8 and bail out if the aircraft is on fire.
http://www.ntsb.gov/aviationquery/br...99FA113&akey=1
R.I.P.
Neal Howard
Airplaneless once again...
Old 08-14-2014, 03:33 PM
flyboy1963's Avatar
Default wind tunnel, or uber-simulator?
how about bolting an -8 fuse to the back of a flat-deck, and taking it down a deserted Nevada highway at 100 kts? Pop the canopy, see if you can send it skyward...attached with a lanyard to keep it off the road of course!
...or perhaps Paul Dye knows where to find a 747 that we could piggyback an -8 onto? ( might be one parked somewhere with a 'for rent' sign on it?!)
heck, could test the entire Van's fleet at once!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 08-14-2014, 03:38 PM
KRviator's Avatar
KRviator KRviator is offline
Why limit it to just the -8's? As a soon-to-be -9A driver I'm interested in knowing if my canopy will depart cleanly too. And what about the 10's and their gullwing doors?
They won't do it, no matter how many people write to them for the simple reason the risk doesn't justify any potential reward.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
