Old 07-05-2014, 07:26 AM
colestopp colestopp is offline
Default -10 rudder trim
I am also a rookie. We are currently awaiting delivery of an RV10 Empennage and this was my first question as well! Reading some of the excellent build websites I see rudders being built early on and people cutting chunks out of them. I am thinking 'EEK!', I don't want to be doing that at an early stage! So rudder bias looks like the perfect answer to me. But then I see another post saying it does not work with....what exactly? In what circumstances can you not fit this simple bias system? We want to have an IFR aircraft ultimately. Does that have any bearing?
Old 07-05-2014, 07:35 AM
rleffler's Avatar
rleffler rleffler is offline
The Aerosport Products rudder trim works just fine. The problem that some builders run into when installing the trim as an after thought are too many devices contending for space under the panel.
The trim requires a straight shot from the rudder bars to wherever you mount the control. If you take that into account as you lay out your panel and harness, there isn't an issue. Just ensure nothing extends below the sub panel perpendicular to where you mount the control box.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 07-05-2014, 09:45 AM
N941WR's Avatar
N941WR N941WR is offline
...Reading some of the excellent build websites I see rudders being built early on and people cutting chunks out of them. I am thinking 'EEK!', I don't want to be doing that at an early stage! ...
Welcome to VAF!
Some of the trim systems I see are simply to rivet on a section of piano hinge to the trailing edge and mount a servo in the rudder.
Try using the search function and see what comes up.
Here are a couple of good threads on the subject:
http://www.vansairforce.com/communit...ad.php?t=64320
http://www.vansairforce.com/communit...ad.php?t=23591
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-05-2014, 10:04 AM
Default rv10 rudder trim
Thanks! We have a slightly different system in UK in that changes from standard have to be approved. I have now discovered the no one in UK has chopped a bit out of the rudder, so that is not a sensible option for me. It will be rudder bias or nothing in our case!
Old 07-05-2014, 10:16 AM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Other than climbs and flares, my plane flights straight so I havent found a need for a rudder trim. I think most people that want/use one are because they are worried about holding right rudder for extended climbs. I really dont notice it.
CharlieWaffles - But you can call me "Mark"
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 07-05-2014, 10:52 AM
Default Welcome to VAF!
I am also a rookie.
Stephen, welcome to VAF
I did the cut in tab in the rudder, servo driven and controlled with the Cooley hat switch in the stick grip. Works just fine, and I would not want to fly without it.
Others have used Geoff's spring bias system, and feel the same about it.
Choice is yours, do what makes you happy.
Good to have you aboard.
Old 07-05-2014, 03:26 PM
Default rv10 trim
Thanks for that too, and the link to your build site as I had not seen that before!
Old 07-05-2014, 06:05 PM
N427EF N427EF is offline
Default Spring Bias System
Maybe this will work for you.
It works very well for me.
Vans Flap motor or other linear actuator mounted on a rail.
One spring is fixed the other is actuated for and aft.
Controlled via a relay deck and connected to buttons on the stick.
A trim servo is not strong enough and actuator travel is too short.
Side benefit: No need to cut up the rudder and spring tension keeps the rudder from flopping around. This is only true for "light wind" conditions.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Don't believe everything you know.
Old 07-06-2014, 07:20 AM
flion's Avatar
flion flion is offline
Actually, I want it more for extended slow flight. I plan to fly to Oshkosh when mine is finally completed and I just know, with my luck, I'll get stuck behind a Cub.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 07-06-2014, 08:46 PM
douglassmt douglassmt is offline
Default +1 for Aerosport Rudder Trim
If your -10 is like most, you will need a little rudder trim in cruise and it can vary as you use/switch tanks, change aileron trim, etc. I used Geoff's trim system because it is simple, inexpensive, and it works. I flew without any rudder trim for a few dozen hours before Geoff produced his long-awaited product. I set it initially with some slight right trim (of course) and rarely move it more than 1/8 of a turn, just tweaking it slightly in flight. Remember, keep it simple. It doesn't need any metalwork, circuit breakers, carving on the rudder, motors, relays, or hinges. Oh, and did I mention that it works?
Bryan Douglass
=VAF= 2020 dues paid
RV-10 N242BD
