POSTING RULES
Donate yearly (please).
Advertise in here!
Today's Posts
Insert Pics
12-28-2013, 09:07 PM
P-Mag "B" Curve Advance Map
I decided today was the day to put the P-Mag monitor that I built a couple years ago to the test and use it to map out the advance curve on the P-Mag. (Dan Horton suggested this in another thread)
This is a P-Mag set to the factory settings using the "B" curve and the manifold pressure line is connected.
Hope this helps settle some dust around the mysterious P-Mag advance curve.
One thing that I noticed is how the P-Mag is advancing the timing even at high power settings by about 7°. Based on the info David (RV10inOz) has been providing I am definitely going back to the "A" curve and may make more drastic changes with the software..... I have always had to limit climbs due to hitting my personal limit of 410°, this may help.
12-28-2013, 09:20 PM
I am just an observer in regards to EI, but I thought that the bottom right of the chart was supposed to be populated with 25 degree timing for either A or B curves.
Thanks for the data Brian
Bill Pendergrass
ME/AE '82
RV-7A: Flying since April 15, 2012. 850 hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'... Eyeballin' vinyl really hard.
Yeah. The boss got a Silhouette Cameo 4 Xmas 2019.
12-29-2013, 06:07 AM
The B curve is offset no matter what by the amount entered into "adv shift/constellation shift" field inside EICAD or with Bill's EICommander.
I chose an RPM and MP range that a typical RV may use. I have no idea if the advance would go lower at RPMs and MP off of my chart but I really am not interested in those areas since I never operate there.
I can tell you that I was shocked to see it advancing over 7 degrees on a full power climbout at my field altitude but I should not have been. The manual spells this out pretty clear. If I had noticed this before, I would not have been using the B curve all along. My mistake for not reading the manual well enough.
12-29-2013, 06:22 AM
Holy cow!
There's no good reason to have ANY advance at full power.
Please don't PM me! Email only!
Bob Japundza CFI A&PIA
N9187P PA-24-260B Comanche, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
12-29-2013, 06:28 AM
Originally Posted by rocketbob
Holy cow!
I agree. These EI makers need to make their default timing MAPs available so that people don't have to go thru this to understand what their ignition is doing.
I have no idea why I waited so long to do this after installing the CS prop, I should have done it sooner. It would have been real hard to impossible to do with the FP prop.
12-29-2013, 06:38 AM
Oh and I can tell you the engine does not like being forced to 1800 RPM at 23-27" MP. At least it did not feel comfortable to me!
12-29-2013, 06:57 AM
Say Brian, would you happen to also have a similar chart for the "A" curve? Or perhaps Emag makes that available somewhere and I've just missed it... there is a chart printed in the install manual, but it says something like "for illustration only, does not represent actual timing curve".
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
12-29-2013, 07:03 AM
Not yet Matt but I plan to map out the "A" curve next flight.
Emagair has never made these maps public to the best of my knowledge.
12-29-2013, 07:56 AM
Holy cow!
The manual states the B curve simply shifts the entire curve 5 degrees
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
12-29-2013, 08:39 AM
The manual contradicts itself and is inconsistent in several places as well as does not match the real world data.
One reason I decided just to map the curve myself.
