Go Back   VAF Forums > Main > RV Building Tips/Techniques
Old 09-02-2006, 11:16 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Tip: Paper Clips & Baffle Fits
When initially fitting the engine baffles, the ubiquitous paper clip can be an excellent time saving tool to assure a sufficient and consistent clearance between the baffles and the lower surface of the upper cowl.
Just barely insert number of paper clips onto the upper edges of the baffles making sure they sit upright and proud, then temporarily set the upper cowl in place. The paper clips will be pushed down onto the baffles thus giving the builder a fairly accurate way to determine how much material must be trimmed away to assure adequate clearance prior to installing the rubber seals.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 09-02-2006, 02:19 PM
cytoxin's Avatar
cytoxin cytoxin is offline
Default play dough
now i wont have to waste my kids play dough good tip
William Weesner/ still kicking.
Old 09-02-2006, 04:01 PM
Finley Atherton Finley Atherton is offline
Excellent idea with the paper clips.
Here is a method that worked for me. Before I did any trimming I secured (duct tape ?etc?) the top cowl in it's correct position above the bottom cowl so that there was an even gap on both sides between the cowls (cowls parallel to each other). Measure this gap and add the required clearance. For example, if the gap is 3? and the clearance is 3/8? the total is 3 3/8?. Make up a spacer to this length (I used a popsicle stick). Remove the bottom cowl. Now reach in and holding the spacer vertical against the baffle and touching the secured top cowl, use your felt pen to mark the baffles for trimming all around. You should now have a line on the baffles that is 3 3/8' (for example) vertically below the lower surface of the top cowl all around. If you feel really brave then start cutting on the line. I suggest trimming maybe 1/8 or 1/4" above the line and see how it looks. You could use the paper clip method now to check the clearance.
Warning. This worked for me, it may not work for you. Don?t blame me if you have to get new baffles because you cut your old ones down too much.
Fin
9A Australia
