Go Back   VAF Forums > Avionics / Interiors / Fiberglass > COMM
Old 07-25-2013, 06:14 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post New (July 2013) Garmin GTR 200 10 Watt COM Radio for Experimental Aircraft
Garmin is pleased to announce the new GTR 200 panel mount COM radio which was desgined specifically for experimental and light sport aircraft.
The GTR 200 offers a slim design (1.35" high) and powerful features including advanced auto-squelch, 3D audio, stereo intercom, stereo music input, dual alert inputs, best-in-class standby frequency monitoring, on-screen frequency identification, and much more.
A sunlight readable display with large easy to read text and frequency identification labels means you never forget which frequency is tuned. Two user defined softkeys let you have immediate access to functions like pilot isolate and music on/off. Large, high quality knobs with a great feel are a pleasure to use.
Many radios support user defined frequency presets, but few are so easy to enter and use. Large 10 character labels make it easy to identify airport and frequency type. To select a user frequency, simply press the inner dual knob, select the USER frequency group with the outer knob, and then use the inner knob to select the frequency and transfer to the standby position.
When the GTR 200 is connected to a Garmin G3X EFIS, select Garmin portable GPS units, or many other experimental EFIS systems which support the legacy SL40 protocol, flight plan and nearby airport frequency groups are constantly and automatically transferred over a serial link into the GTR 200 for easy use.
To see all of the frequencies for an airport (for example KOSH has 7), push the inner knob, select the airport with the outer knob, then select and transfer the frequency to the standby position. Nothing complicated or confusing about using this powerful feature.
A large volume bar with numerical level indication makes it super easy to restore your favorite COM volume every time. Press the MENU key and you can quickly adjust both intercom and music volume.
The 3D audio feature provides spatial separation of the active frequency, monitored standby frequency, and pilot/copilot audio streams, making it even easier to recognize that you are receiving on the active or standby frequencies without looking for the RX indicator.
The GTR 200 has a front accessible micro SD card for user installed software updates should these be needed.
The GTR 200 does not have an installed database, yet is able to use frequency information from attached devices to perform automatic frequency identification of manually tuned frequencies. Hundreds of nearby frequencies/IDs are automatically and constantly transferred to the GTR 200 by G3X (V8.20 and later) and Garmin Aera 5XX/660/7XX and GPSMAP 69X portables.
The expanded protocol to perform this enhanced feature is publicly available making it possible for any brand EFIS to integrate in this manner with the GTR 200.
The GTR 200 is easy to install, with a standard density 37 pin connector and support for both 14 and 28 volt aircraft. The GTR 200 is 10 Watt and supports 25 kHz channel spacing.
The GTR 200 is expected to be available in August for a Minimum Advertised Price (MAP) of $1,199.
For more detailed information, specifications and a comprehensive lineup of all our products for Experimental and Light Sport aircraft please visit Garmin.com/experimental or contact your Garmin dealer.
Here is a link to an demonstration video made at Oshkosh this week.
AvWeb Product Minute: Garmin's GTR200 Radio with 3-D Audio
Come visit us at Oshkosh to see and discuss this new product. We will be giving a seminar Mon-Sat at 1:00 PM which will present this new product and the other new for 2013 G3X system components.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Last edited by g3xpert : 03-07-2016 at 05:03 AM. Reason: Updated to show compatibility with aera 660
Old 07-25-2013, 06:41 AM
Mike D's Avatar
Mike D Mike D is offline
Nice product!
Like the looks, that the database is not mandatory, the user update-ability, and the open source frequency transfer.
Good job guys.
Will the 3D sound require a special headset?
Michael Delpier
RV6A -O-320, fixed pitch, GRT Sport, 496
RV-10 - working on finish kit
Houston
Old 07-25-2013, 06:42 AM
Pdtofly Pdtofly is offline
Default New Comm
Nice unit.
Do you plan on offering it with 8.33 kHz spacing in the future?
Thanks.
Brian
Old 07-25-2013, 06:46 AM
Kahuna's Avatar
Kahuna Kahuna is offline
I went to check out the install and operators manual from your product link and both links to the docs are broken.
You know us builder types are always looking at the details.
https://buy.garmin.com/en-US/US/prod140495.html
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
Old 07-25-2013, 06:53 AM
g3xpert's Avatar
Post
Originally Posted by Mike D View Post
Nice product!
Good job guys.
Hello Mike,
Thanks for your kind words. The GTR 200 can be used with either stereo or mono headsets, but to receive the benefits of 3D audio, you must use a stereo headset.
Brian - we haven't ruled out offering a 8.33 kHz capable model, but nothing to communicate at this point. We do, of course, offer the GTR 225 in an 8.33 kHz capable model.
Kahuna - manuals should be posted soon. (update - available now)
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 07-25-2013, 06:57 AM
jthocker's Avatar
jthocker jthocker is offline
Wow! Great new product. Can't wait to read what the nay sayer's will complain about!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 07-25-2013, 07:05 AM
Walt's Avatar
Walt Walt is offline
And it looks like this should squeeze into the old SL40 slot which is 1.30" high, nice
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 07-25-2013, 07:17 AM
Snowflake's Avatar
Wow... Nice! Any chance it would be tray-compatible with an iCom A210?
I think the only thing missing is Bluetooth. If it had that, I'd buy it today.
Rob Prior
Old 07-25-2013, 07:38 AM
g3xpert's Avatar
Hello Rob,
Sorry, no if you mean pull out the A210, leave the A210 rack, insert the GTR 200 into that rack.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 07-25-2013, 07:39 AM
ColoRv's Avatar
ColoRv ColoRv is offline
Nice! Isn't this the third radio you guys have released this year? Combined with autopilot, servos, etc....I have to wonder, are you getting any sleep at all Garmin?
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
2015 Sun n Fun Kit Built Reserve Grand Champion
2015 Oshkosh Kit Built Champion
2015 Jeffco Kit Built Grand Champion
2014 Oshkosh Outstanding Workmanship Award
Broken Warrior of the Jarhead Clan
