Old 02-27-2012, 07:30 PM
pilot2512 pilot2512 is offline
Default Wing J-Stringers centerline
Got just up to installing the W-926A/B j stringers in my wing today. I drew the center line as per the plans (3/8" from unbent end). When I install it in the wing the line is too high and I cannot lower it any more since it is hitting the ribs. Seems like I could just install the j-stringers touching the ribs and not need the line. What have other people done?
thanks
Jay
RV-9A
Empennage complete.
Wings complete.
Fuselage in progress
Wiring in progress
2020 Donation made!
Old 02-28-2012, 12:16 AM
bruceh's Avatar
bruceh bruceh is offline
I adjusted the distance slightly (5/16" instead of 3/8") to keep the stringers from hitting the ribs. I'm pretty sure I've seen other builder web logs that mention this issue.
The plans also wrongly call out for the end of the stringer to go to the end of the skin. It just needs to go flush with the rib. Otherwise it will interfere with the fiberglass tips.
Bruce Hill
RV-9A N5771H flown over 700 hours!
2020 VAF donator
EAA Tech Counselor, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 02-28-2012, 06:47 AM
swixtt swixtt is offline
that is exactly what we did as well... just changed where the line is so it is centred in the cut-out in the rib.
when you install them, put both a and b in so the overlap(about 3 rivet holes worth) can be slightly adjusted to keep it centred.
RV9.... Tail done. Inspection done! Wings pre-cover MDRA inspection done. Closing them up now. Fuse underway.
Old 02-28-2012, 10:32 AM
airguy's Avatar
airguy airguy is offline
Yup - what they said.
Here's another tip for you - cut the J-stringer flush with the end of the rib on the wingtip end (like Bruce's picture) instead of letting them run long to the edge of the skin. When it's time to put the fiberglass wingtips on you'll end up taking a dremel tool to that J-stringer otherwise.
Ask me how I know...
Greg Niehues - SEL, IFR, Repairman Cert.
Garden City, TX VAF 2020 dues paid
N16GN flying 650 hrs and counting! IO360, SDS, WWRV200, Dynon HDX, 430W
Built an off-plan RV9A with too much fuel and too much HP. Should drop dead any minute now.
Old 02-28-2012, 06:05 PM
Default Thanks!
Thanks for the advice. That measurement work out perfect. I caught the extra length on the wingtip side and made the executive decision to make it flush with the rib the first time I slid it in. Figured since there was no rivet hole past the rib it wasn't necessary.
Jay
RV-9A
Empennage complete.
Wings complete.
Wiring in progress
2020 Donation made!
Old 02-28-2012, 06:48 PM
It depends on the side. This one I cut short and the next one was installed correct.
Old 02-28-2012, 07:01 PM
Good work...
Old 05-11-2020, 06:55 AM
eric.the.blonde eric.the.blonde is offline
Default Still a gotcha.
I bought my wing kit in the spring of 2018 and the assembly instructions still have the same issues: 1) calls for 3/8" but should be more like 5/16", and 2) calls for aligning with edge of W-903 but should be W-902.
For the record, I'll be taking a dremel (as stated in a prior post) to the first wing I built. I finally realized the problem AFTER match drilling the j stringer on the second wing. At least I can trim that one before final assembly.
I glad to hear that planes are not falling out of the sky having that extra half inch gap between the outer stringer and the inboard skin.
Eric G.
Ann Arbor, MI
RV-9A under construction (wings)
President, EAA Chapter 333 Flying Stinkers
