Old 12-02-2019, 07:38 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Default Lean Warning Settings
Something that has cropped up a few times recently that has confused some aviation customers using wideband O2 sensors hooked to the grey wire for AFR display into the programmer- When they are leaning, suddenly the AFR goes very rich and they get an O2 Error.
There are a couple settings in the programmer- Lean Warning and Lean Warning + Add Fuel. When the latter is turned on, the ECU automatically adds about 25% more fuel when it detects the AFR going leaner than 14 to 1 for more than a few seconds to protect the engine.
In aircraft applications where you'll be running near or lean of peak, these settings should probably be turned off to avoid both the warning and especially having the ECU intervene.
Hope this helps some folks who are wondering what is happening here.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 439.3 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 12-05-2019, 01:05 PM
rv6ejguy's Avatar
Default December
We've received a lot of CPI-2 and EM-5 orders this week, so much so that we're fully booked on these items until the end of 2019. Thanks to the many folks here on VAF for their orders. We really do appreciate it. It's been our best year since 2006 and we're plowing a lot of that capital back into developing the new EM-6 items and projects like the Rotax 912 kits for introduction in 2020.
As far as billet parts go, we have pretty good stock on intake flange kits and PV valve covers currently. A bunch more flywheels should be off the lathe by tomorrow. We can still fulfill orders for these items this month.
Old 12-08-2019, 03:47 PM
rv6ejguy's Avatar
Default Rev Limiting
I've heard of a few prop governor problems over the last year or so. In the case of over rev protection, SDS CPI, CPI-2 and EM-5 can all be set to limit maximum rpm. We recommend you set the limit to around 100 over the max you want the engine to go.
On CPI and CPI-2, the window is called Rev Limit or Limiter.
On EM-5s, it's called Fuel Cut/RPM.
Old 12-19-2019, 07:23 AM
rv6ejguy's Avatar
Default Manual Updates
A few days ago I uploaded some revised manuals which have updated information on the new Design1 programmers. See the Aircraft Page under Documentation.
Production is booked up through the first part of January now. Thank you very much to all those who ordered SDS products in 2019!
