Old 12-02-2019, 06:55 AM
JDA_BTR JDA_BTR is offline
Default Which Epoxy Primer
I used AKZO green primer last time (463-12-8/CA-116).
I liked the hardness/toughness, quick dry, etc. But I wish it was a different color.
What epoxy primer wears like AKZO and has the same fluid resistance but is dark grey?
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 12-02-2019, 07:34 AM
iwannarv iwannarv is offline
Stewart Systems EkoPoxy gives you color choices (light and dark gray). It is a waterborne 2 part epoxy. I used Akzo as well and like the product, but looking for something that isn't so toxic in future projects.
Brad Brensing
RV-10 Emp/Tailcone - Complete, QB Wings - Building, Fuse - Building
Never judge a man by his trim tabs.
Old 12-02-2019, 07:35 AM
There are some good water based primers but I like the quick dry better....
Old 12-02-2019, 08:49 AM
I used both Stewart's epoxy primer, which I liked, and Eastwood's rattle-can epoxy primer, which is okay. The Eastwood is certainly convenient, if expensive and wasteful.
Stewart's epoxy has had people comment about it being hard to apply. I found it quite straight-forward and had no real trouble. Like I said, I like it.
Can't comment on durability or fluid resistance, though, for any of these.
My landing gear legs are Azko's green epoxy primer, and it's durable.
One thing that might not matter to you, is that both Stewart's and Azko's (no info on Eastwood's) can be epoxied to, and will develop a structural bond. For me, that was a plus on the main gear legs, because of the wooden stiffeners. But I haven't gotten that far yet.
Dave
Old 12-02-2019, 10:24 AM
lr172 lr172 is offline
southern polyurethanes makes an excellent and affordable epoxy primer. However, the grey is between light and medium.
N64LR - RV-6A / IO-320, Flying as of 8/2015
N11LR - RV-10, Flying as of 12/2019
