Question on microphone jack❓❓❓
romanov
Guys a small question about wiring
my mic jack:
I see that the plug has two sections
that could be the "ring".
If I wire ring section number "1" I get
constant transmitting as like I press the PTT.
If I wire number "2" as a ring I don't transmit
any mic voice out.
All the rest of the radio work correctly. I do get
transmitions and can hear the audio on my headset.
Any tip on how to wire them correctly?
It sounds as if you accidentally wired the PTT line to the terminal you labeled 1, instead of the mike hi input. Nothing you do to the mike input should trip the PTT.
