Old 04-13-2017, 03:49 PM
spaceflightmeow's Avatar
spaceflightmeow spaceflightmeow is offline
Default VAF forum emails from (unknown sender)
Whenever I get emails from the VAF forums (for PMs, subscribed threads, etc), Gmail flags them as (unknown sender) and marks them as spam. Google's reason: "It is in violation of Google's recommended email sender guidelines. "
A snippet from an email header of a VAF email gives some clues:
Code:
Return-Path:
...and then further down..
Code:
Return-Path: <>
Maybe the blank From address or blank return path have something to do with it? I googled "vbulletin messages marked as spam" and found this
https://www.vbulletin.com/forum/foru...-spam-in-gmail
It says:
You may want to try to change the webmaster email to an email address from your domain name. You should also try the -f option and if that does not work, you can request that your host check their mail settings/error logs or contact gmail to determine why you are being flagged as spam.
Doug, it would be great if you could fix this.
Into the blue again, after the money's gone
RV-7A
Empennage complete minus glass work.
Wings kit in progress.
Old 04-13-2017, 04:45 PM
Good luck what that. :-)
(Do a forum search on the subject.)
You found the reason, just not a solution.
[ed. Next revision. v/r,dr]
Old 04-13-2017, 06:00 PM
BillL BillL is offline
Default Is it the SPF listing?
Received-SPF: neutral (google.com: 204.144.126.109 is neither permitted nor denied by best guess record for domain of postmaster@webserver30y) client-ip=204.144.126.109;
Authentication-Results: mx.google.com;
spf=neutral (google.com: 204.144.126.109 is neither permitted nor denied by best guess record for domain of postmaster@webserver30y) smtp.helo=webserver30y {formatting added}
Shouldn't the sender domain for VAF be listed in the SPF? According to another google post, if the review is "neutral" then gmail sees it as spam. "Sender Policy Framework"
I see Dr's comment now . . .
In the voice of Roseanne Roseannadanna - Never mind.
Bill
Lord Kelvin:
I often say that when you can measure what you are speaking about,
and express it in numbers, you know something about it; but when you
cannot measure it, when you cannot express it in numbers, your knowledge
is of a meager and unsatisfactory kind.
Old 06-01-2018, 12:55 PM
romanov's Avatar
romanov romanov is offline
Question
Yeah, that is still killing my email notifications,
any chance the admins will fix it.
Thanks in advance
- Roman.
Old 10-22-2018, 09:17 AM
llavalle's Avatar
llavalle llavalle is offline
Any update on this. Since we can't use tapatalk or similar because we need ads (I'm ok with that).. mail notifications are a big thing that's not working now..
Edit : after some digging, this has been discussed more than once... but for some reasons I could only find this post...
So, anyway, I made a filter in gmail to never mark them as spam by looking for the text "VAF Forums" in the body. Here's the link to the explanation : http://www.vansairforce.com/communit...5&postcount=22
Philippe Marseille
RV-9A Kit Emp done, wings @50% - SOLD
RV-12iS@Empennage
Construction Web Cam
Old 01-05-2019, 11:33 AM
llavalle's Avatar
Looks like it's not working anymore.
Not even going to spam... not sure why.
Philippe Marseille
RV-12iS@Empennage
