GAP-26 controller, wiring, and Pitot/AOA tubing run. Bracket and mounting items complete for probe. Garmin GSA-28 Roll servo installed right wing along with wiring. All wiring for Zip Tip III's run thru both wings. Tanks have been off, leak tested, and reinstalled. Aileron and flap pushrods have been set for neutral positions and flaps and ailerons now removed. Wasn't planning on installing electric aileron trim. Is there anything else I should consider or a reason I should wait to close the wing up with the lower outboard skins?
