Old 08-11-2019, 05:29 AM
GPV GPV is offline
Default Cutting Rudder Stiffeners
Hi All,.
I'm just about to cut my rudder stiffeners to size and was wondering if anyone has any tips before I go butchering them. How did you do yours?
Many thanks,
Greg
Old 08-11-2019, 06:08 AM
mulde35d's Avatar
mulde35d mulde35d is offline
Default Band saw
A band saw with a metal cutting blade was easy and accurate. I would highly recommend it.
Jon
http://www.mykitlog.com/mulde35d
RV-14A Sold
RV-10 Research In Progress
Old 08-11-2019, 06:32 AM
MS19087's Avatar
MS19087 MS19087 is online now
Default Bandsaw
Plus 1. Bandsaw!
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 08-11-2019, 07:22 AM
DavidHarris DavidHarris is offline
Default cutting stiffeners
Bandsaw works well. I had access to a sheet metal shop and could just punch out along the marked lines, which was even easier.
In either case, touch up the edges and remove the sharp corners with a scotch brite wheel afterward.
David
Old 08-11-2019, 07:41 AM
Steve Steve is offline
I used the throatless shear in the sheet metal shop. I also had good luck using a heavy duty paper cutter like the one in the copy room at work.
Five Sierra Fox
RV-9A
Utah
Old 08-11-2019, 09:01 AM
N804RV's Avatar
N804RV N804RV is offline
I used a cut-off wheel on a RotoZip, then finished to size with a 3M 6" medium deburring wheel mounted on a bench grinder. Fast and efficient.
The el-cheapo bandsaw I bought from Homedepot was not up to the task.
Ken W.
Mount Vernon, WA
2020 VAF Supporter
Old 08-11-2019, 09:30 AM
fl-mike's Avatar
fl-mike fl-mike is offline
Not sure about the 14, the the 8 rudder stiffener trim length fit on my 6" corner notcher. I did all of them in about ten minutes with a resulting very clean cut. It was like "butter"! But of course you have to have a notcher handy. It can be a handy tool for small trim jobs and such. I found mine (Diacro) on Craigslist for cheap.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS, L3 Lynx NGT-9000
N164WM
N184WM reserved (RV-8)....finishing kit in progress. Titan IOX-370
Old 08-11-2019, 03:24 PM
mturnerb mturnerb is offline
Agree with others re using bandsaw. I shaped all these types of parts and also did much of the deburring of many other parts using a Harbor Freight buffer on a stand (https://www.harborfreight.com/6-inch...psugg_q=buffer, https://www.harborfreight.com/univer...=grinder+stand) and 6" scotchbrite wheels (I used two on my buffer - one finer, one more coarse. The coarse one is great for removing extra material from trimmed parts.
I like the buffer better than a grinder because the spindles are longer and there are no guards on the wheels - makes it much easier to position a part just right to work on it. It takes some practice to avoid damaging thinner parts (some thinner parts I just deburred using other methods).
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
Old 08-11-2019, 04:01 PM
GPV GPV is offline
Thanks everyone, I'll give the bandsaw a go. Hopefully I can rig something up to keep the cuts straight. Dreading this job!
Old 08-11-2019, 09:37 PM
tyconnell's Avatar
tyconnell tyconnell is offline
Bandsaw - I created a jig:
I believe the clamp attached to the board is a toggle clamp.
I rounded the corners after cutting using the disc sander portion of a desktop belt sander, and finished with a Dremel 500 wheel. For flimsy parts like the stiffeners, I prefer this smaller wheel to the scotch brite wheel.
Ty Connell
ty.connell@gmail.com
Donated 2020
