Old 10-30-2017, 10:52 PM
Bicyclops Bicyclops is offline
+1 for white backlight, dimmable
Ed Holyoke
Old 10-31-2017, 07:56 AM
Aw, come on Ross, it's only a couple extra solder pads and some software....Let each customer pick their own. ;-)
https://www.google.com/search?q=tric...hrome&ie=UTF-8
Old 10-31-2017, 08:08 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
The backlighting is built into the display and we'd do a bulk purchase on one type to get better pricing. They typically don't extend the same pricing if we order several PNs.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 10-31-2017, 08:21 AM
The (apparently poorly framed) joke is to use a tri color (RGB) LED, & software lets the user pick their favorite color.
Old 11-01-2017, 05:53 PM
rv6ejguy's Avatar
We ordered a bunch of displays today from several vendors to evaluate hot and cold performance, contrast and viewability.
Contemplating processors now with an eye towards having enough timer and analog channels for future expansion.
Old 11-04-2017, 01:04 PM
rv6ejguy's Avatar
We've found some ways to reduce some pins used on the CPU chip to allow the use of the present 80 pin package in the new unit. The higher pin version took up too much board space.
We've received a couple displays now and some more will come next week. Hopefully I can post some photos here so people can comment on what they prefer.
Component layout is slowly progressing. Much thought is going into the best way to have the keypad communicate with dual boards, the backup battery charging strategy and how best to incorporate some of the new features.
Old 11-07-2017, 04:09 PM
Chkaharyer99 Chkaharyer99 is offline
Will the current crank trigger work with the new CPI2? The reason I ask is, my condition inspection is coming due in December and I'd like to add the SDS crank trigger sensors and flywheel magnets while I have my CS prop off for factory inspection and maintenance.
Charlie
RV-8
Old 11-07-2017, 04:44 PM
rv6ejguy's Avatar
Yes all FF hardware will be the same.
Old 11-07-2017, 04:51 PM
rv6ejguy's Avatar
Yesterday we were working on software to allow the single instrument face/ keypad to communicate with dual PCBs. Also working on the clearest control strategy for those functions. Leaning towards some colored micro LEDs to differentiate between primary and secondary PCBs to avoid a button push on the keypad.
Old 11-07-2017, 05:33 PM
maus92 maus92 is offline
I'm do that right now; the prop's off, and just got the SDS today!
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
