Old 10-25-2019, 05:42 PM
Brent 801's Avatar
Brent 801 Brent 801 is offline
Default G3X Erratic Engine indications
I'm in phase one testing with my new RV-14A. I have a persistent problem with MAP and Fuel Pressure indications simultaneously becoming erratic after about 30 minutes of flight. MAP begins fluctuating about .5 inch while FP fluctuates about 4 PSI. I've checked all connectors on the Stein built harnesses and they look fine. I've replaced the MAP sensor and tested the FP sensor with regulated air pressure. I've had 2 A&Ps and an avionics tech look over my installation. I'm about to replace the GEA-24.
Has anyone had a similar experience?
Brent
Built 2012 RV-8 81764 (sold)
Flying 2019 RV-14A 140229
Donation 12/18
Old 10-25-2019, 07:02 PM
mulde35d's Avatar
mulde35d mulde35d is offline
Default likely checked
You probably already checked, but would ask if you have the modified oil/fuel restrictor fitting on the fuel pressure port. I have also seen -3 hose used for manifold pressure as opposed to -4. Curious what size hose you have.
Of note, I am not flying yet and simply offering areas that may be a factor based upon internet research alone.
Jon
http://www.mykitlog.com/mulde35d
RV-14A Sold
RV-10 Research In Progress
Old 10-25-2019, 11:51 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Default Fluctuating MAP on G3X
I had a problem with MAP becoming erratic as the engine RPM approached 2400 RPM. My MAP line was installed per Van's plans on an IO-360-Axxx engine.
Garmin recommends installing an Omega Engineering PS-8G snubber/restrictor on the MAP line at the transducer.
B
Brian Decker
Retired Firmware Guy and Airplane Builder
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 10-27-2019, 04:31 PM
Tom023 Tom023 is offline
Just got back from 4 hour flight and mine acts similarly. My MP fluctuates upto about 0.8 or 0.9, FP was fluctuating a few PSI. Just my opinion but probably nothing to worry about. If these were analog gauges wouldn?t even be noticeable.
RV14A #140083
Flying! 8/12/19
2019 Donation
Old 11-09-2019, 03:36 PM
Brent 801's Avatar
A new GEA-24 solved the problem.
Donation 12/18
