Old 10-28-2019, 12:39 AM
rjbob rjbob is offline
Default Electro-Air Electronic Ignition Question
I am replacing my duel Lightspeed Plasma electronic ignition (in my RV-7...IO-360) with a single Electro-Air system alongside a standard magneto.
The Lightspeed unit I'm replacing uses the Hall Effect sensors.
The magneto will be on the left. I haven't yet acquired the mag.
I have already purchased the Electro-Air single system.
Can anyone with (or without) experience doing this offer any suggestions?
THANKS!
Bob Edison
RV-7 N749ER...(GO NINERS)
ATP CFI-II-ME
Anchorage, Alaska
Let me know if you're RVing to Anchorage!
Old 10-28-2019, 07:03 AM
rmarshall234 rmarshall234 is offline
What you are going to is the exact set-up I had on my RV-3 w/ an O-320. I had the mag pick-up instead of the external sensor. It was The Bomb. Any particular questions? I wouldn't install a timing advance system w/o a cockpit display of the timing read-out, however.
Old 10-28-2019, 07:54 AM
cajunwings cajunwings is offline
Default Mag/ElectroAir
Not sure exactly what you are asking? Looked after a couple RVs with this setup. Both had the MTH installed in place of the right mag, and coil pack on upper firewall. 1 plane had control box on engine side of firewall, other had it inside(ElectroAir recommends inside). Both had MAP sensor in engine compartment (I think now they recommend inside for that as well). I think switches work better for the run up checks of this ignition setup than key switch. I probably have a couple photos I could email to you.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 10-28-2019, 07:56 AM
chaskuss chaskuss is offline
Default What version?
Bob, what version of the Electroair electronic ignition did you purchase? Is the pickup mounted in the right mag hole or is the pickup counting the teeth on the starter ring gear?
Charlie
Old 10-28-2019, 08:04 AM
Originally Posted by cajunwings View Post
Not sure exactly what you are asking? Looked after a couple RVs with this setup. snipped 1 plane had control box on engine side of firewall, other had it inside(ElectroAir recommends inside). Both had MAP sensor in engine compartment (I think now they recommend inside for that as well) snipped
Don Broussard
57 Pacer
Definitely install the control box and preferably also the map sensor inside the fuselage. In the automotive World about 95% of all cars and trucks have the PCM ( powertrain control module AKA engine computer) installed inside the passenger compartment of the vehicle. The other 5% have the PCM installed under the hood. Guess which vehicles are notorious for PCM failures??? Anything electronic has two enemies, heat and vibration. Under the cowl you have bucket loads of both. Consider putting a blast tube on the coil pack to help keep it cool. That will help extend the life of these components. Try to mount them on the firewall somewhere that will keep them away from the worst heat under the cowl.
Charlie
Old 10-28-2019, 12:54 PM
Ralph Inkster Ralph Inkster is offline
Be sure the control module and coil pack housings are WELL grounded, otherwise follow the factory install instructions which are straight forward.
Ralph
It's time to work on just my own planes, not everybody else's...
Old 10-28-2019, 03:30 PM
lr172 lr172 is offline
Charlie
My BMW has the ECM under the hood. 180000 miles without incident. That said, I wouldn't necessarily expect the electroair to be as hardened as the Bosch units.
N64LR - RV-6A / IO-320, Flying as of 8/2015
N11LR - RV-10, Flying as of 12/2019
Old 10-28-2019, 03:39 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Many auto OEMs have the ECM under the hood over the last decade. Reliability doesn't seem to be an issue in my experience on the better brands. Electronics are much more robust post 2010ish than they were in the 1990s.
That being said, some of the brands of aircraft EIs I've seen are nowhere close in design or component quality to even those 1990 era auto ECMs.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 439.3 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 10-28-2019, 04:24 PM
Charlie
Hello from Alaska, Charlie!
Thanks for the response.
The system I purchased is the EIS-1 MTH Kit 4cyl Lycoming Ignition.
Just starting to go through the manual and it appears that the pick-up will be in the mag hole.
Bob
Bob Edison
ATP CFI-II-ME
Anchorage, Alaska
Old 10-28-2019, 04:30 PM
Don Broussard
57 Pacer
Hi, Don,
Appreciate the response. Photos would be outstanding...Thank you in advance!
My email...bob@jetmodeler.com
When you fly your RV-9 to Alaska, lunch is on me!
Bob
Bob Edison
ATP CFI-II-ME
Anchorage, Alaska
