Old 10-15-2019, 03:41 PM
sblack sblack is offline
Default cleveland brake maintenance
The cleveland brakes on my airplane (other airplane - RV not done yet) are 50 yrs old. There seems to be a lot of play between the 2 pins that the calipers slide on (called anchor bolts) and the bushings that they run in on the torque plate. Does anyone know what sort of tolerances are allowed before replacement is required? I have some evidence that these are jamming in the bushings. They say that you can't buy bushings for the torque plate, you have to buy a new plate for $500CDN. Yes, five hundred, not a typo. When I regained consciousness... Anyway I would like to know if I need to replace that or not, or the anchor bolts. I downloaded a maintenance manual from Cleveland but it did not provide that specific info. Any suggestions?
Scott Black
Old school simple VFR RV 4, O-320, wood prop, MGL iEfis Lite
VAF dues 2020
Instagram @sblack2154
Old 10-15-2019, 05:04 PM
jrs14855 jrs14855 is offline
Default Brakes
I don't have an answer as far as tolerance. If you feel the brakes are dragging polish the pins with some fine emery and then apply some dry lube.
If you still have concerns you might consider reaming the bushings enough to allow a custom made sleeve to be pressed in place. The sleeve could be a bushing made from 4130 tubing and would only need to be approximately .035 wall thickness, maybe a bit less.
Another option would be to check Grove price for the plates or even a salvage yard.
Old 10-16-2019, 08:27 AM
The cleveland document says that the torque plates (at least on some of their brake assemblies) are castings and the bushings are integral and can't be replaced. If I had more info I could machine bushings and press them in. I am fully equipped for that. But I don't want to proceed without knowing exactly what the fits should be. I don't want to have a brake lock up and ground loop because I got it wrong. But paying $500 for a small casting just seems like a total ripoff.
Scott Black
VAF dues 2020
Old 10-16-2019, 02:35 PM
Default Plate
My Cleveland 500 x 5 appear to be all steel with the bushings brazed or silver soldered to the flat plate.
Old 10-16-2019, 02:54 PM
RVDan RVDan is offline
Here is a link to the manual. https://www.parker.com/literature/Ai...CMM0001-12.pdf
They just say, if holes excessively elongated. The eyeball test.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 10-16-2019, 04:45 PM
chaskuss chaskuss is offline
Scott, I just checked my unused Cleveland calipers. The PIN to bushing clearances vary between 001" to .0025" clearance.
Charlie
Old 10-16-2019, 07:38 PM
Thank you Charlie
Scott Black
VAF dues 2020
Old 10-17-2019, 05:44 AM
pa38112 pa38112 is offline
If this is a certified airplane you can not re-bush the piece. You can make a brand new piece from scratch if you do it yourself, but you can not re-bush if the OEM does not approve of that.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 10-17-2019, 08:42 AM
vfrazier's Avatar
vfrazier vfrazier is offline
I have ONE Cleveland torque plate in my shop somewhere. How I ended up with one is anybody's guess.
Nonetheless, I'd be happy to sell it to anyone who needs it. How's $50 plus $10 for Priority Mail sound?
The OP gets first shot at it, since he's the one with the possible problem.
Contact me at vincefrazier@gmail.com No PMs please.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
