Old 08-22-2019, 11:18 AM
HansLab HansLab is offline
Default canopy cleaning
After pulling off the ducktape that was used to protect the canopy against the epoxy i keep glue residue on the canopy: a string of some 25x 3 cm with tiny bits and pieces. Clearly ' feelable' with nails, but not removable yet.
I read this forum and tried (carefully) WD40 and turpentine (first on the inside, to see if there would be any damage to the plexiglass), but no significant results.
In the meantime I've read about polishing the plexiglass - and it does look at the process I've been through polishing the aluminum, but hey: having to sand these stains takes some guts I don' t have at the moment.
What are your ideas, network?
Hans Labruyere
build & sold project Kitfox IV
Project bought & building RV12 #120742
Donation 2020 paid
Old 08-22-2019, 11:57 AM
greghughespdx's Avatar
greghughespdx greghughespdx is offline
If you haven?t already tried it, some simple alcohol to soften combines with a little heat can aid in tape adhesive removal. Also, similar to the idea of using 100LL to clean 100LL stains, it sometimes works to use a string duct tape (like the T-Rex tape we use in packing our kits) to remove tape adhesive.
Be careful with chemicals specified for removing tape adhesive residue on the canopy. Read labels and carefully test. Many of them specify no use on plastics.
Greg Hughes - Van's Aircraft - Community, Media, Marketing
Van's web site | Instagram | Facebook
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Building RV-8A since Sept 2014 (N88VX reserved)
Dual AFS 5600, Avidyne IFD 440, Whirlwind 74RV, Superior XP IO-360
VAF build thread - Flickr photo album - Project Facebook page
Aurora, OR (EAA Chapter 105)
Old 08-22-2019, 12:53 PM
BJohnson's Avatar
BJohnson BJohnson is offline
Default Mineral Spirits
I used mineral spirits to clean adhesive residue off the canopy with good results. It does not attack the plexiglass.
Other options from the chart below are isopropyl alcohol or even gasoline.
Test of scrap plexiglas first.
https://www.eplastics.com/blog/chemi...lic-plexiglass
Brice
RV-9A 90897 FLYING
Old 08-22-2019, 01:48 PM
Search for "orange citrus cleaner". Try on small inconspicuous area first.
Joe Gores
RV-12 Flying
Old 08-22-2019, 02:03 PM
mturnerb mturnerb is offline
I think the rear window in RV-12 is very prone to surface cracks if exposed to gasoline, unless the material has changed.
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
Old 08-22-2019, 06:52 PM
GooGone Goo and Adhesive Remover. Test on small part of plastic first, but I'm pretty sure its OK on both Polycarbonate and PlexiGlass.
GooGone is excellent at removing stubborn / dried tape and label adhesive.
https://googone.com
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 585
LSRM-A Certificate 2016 for RV-12 N633CM
Old 08-22-2019, 08:13 PM
skydiverlv skydiverlv is offline
Peanut Butter Do not laugh, it works!
Larry Vandegrift
ULPower 260is
Old 08-23-2019, 06:39 AM
jrtens's Avatar
jrtens jrtens is offline
+1 on the Goo Gone
Jon
12iS SLSA 8/19
Salt Lake Int'l
Old 08-23-2019, 11:56 AM
Originally Posted by jrtens View Post
+1 on the Goo Gone
That reminds me... sometimes I use GooGone on the prop. Nice and shinny and bugs easier to remove after flight.
EAA #499867
