Old 09-28-2017, 10:51 AM
bkervaski's Avatar
Default Finishing Kit! Woohoo!
That is all
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 09-28-2017, 11:31 AM
Default Hey Bill--
you seem to be making very fast progress! Might be the fastest build of a 14 yet ?
Tom
Ridgeland, SC
Old 09-28-2017, 11:40 AM
bkervaski's Avatar
I think Jared_Solomon gets that award! He finished a slow-build in record time, amazing.
We're averaging 30 hours/week and still have the finishing kit, avionics, and engine. Hopefully it will be ready by March!
Still have some things left behind like some fiberglass to finish up and I'm reworking the brake system a bit.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 09-28-2017, 12:33 PM
Jared_Solomon's Avatar
Jared_Solomon Jared_Solomon is offline
Thumbs up Your almost there
Finishing kit is a big milestone! Do you have the panel/electrical wired up yet?
Jared Solomon
A&P, EAA Technical Counselor
Powder Springs, GA
2020 Dues Paid
RV-14A (N214WJ) - Flying since Sept 2017
RV-7A (N211WJ) Flying since 2009 (SOLD)
RV-7A (N132RD) bought flying 2014 (SOLD)
KPUJ (Silver Comet Field)
Youtube channel: http://www.youtube.com/jmsolomon2000
RV-14 Build Log: http://rv14.jaredsolomon.net
Old 09-28-2017, 01:28 PM
bkervaski's Avatar
The panel and harness is done (thanks, SteinAir!) but not installed ..
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 09-28-2017, 01:39 PM
Talking The end is in sight then
Then end is in sight then =). The pre-wired panel should make it a quicker job. Is your plane on a rotisserie? I had mine on a rotisserie and I got all the electrical work done before putting the canopy, engine mount and landing gear on. It saved me a ton of time, since access was so good. Might be something to consider before moving onto the Finishing Kit steps.
Jared Solomon
Powder Springs, GA
2020 Dues Paid
Old 09-28-2017, 02:18 PM
bkervaski's Avatar
Thanks!
Did you complete your avionics install prior to the Finishing Kit?
Apprehensive about working with the plexi, any recommendations? Did you use plexi bits or a unibit for drilling?
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 09-28-2017, 03:25 PM
Originally Posted by bkervaski View Post
Thanks!
Yes, I did all the avionics work before starting on the finish kit. I made a fuselage rotisserie by using an engine stand and some angle steel. A bunch of pictures at the link below. It made installing the wire harness much easier. It also made running the wires around the sub-panel real easy because I didn't have to lean over the side rails
http://rv14.jaredsolomon.net/post/ot...ge-Rotisserie/
As far as the plexi goes, the canopy comes from Van's almost perfect. There's no "big cut" to do, like on the older kits. Just some minor sanding of the edges to get everything to fit up nice and drilling holes. For drilling the holes, I haven't had good luck using standard 118/135 degree drill bits, it always seems to leave chips and stress fractures around the holes. I recommend using plexi drill bits. I put a link below for some. They have a 60 degree tip angle, and no rake, which works much better with acrylic.
http://www.aircraftspruce.com/catalo...plexidrill.php
Jared Solomon
Powder Springs, GA
2020 Dues Paid
Old 09-28-2017, 03:36 PM
bkervaski's Avatar
Thanks for the info and the link! I actually already had them in my cart
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 09-28-2017, 06:55 PM
Talking Wise you are
Jared Solomon
Powder Springs, GA
2020 Dues Paid
