Old 10-16-2015, 12:56 PM
Harvey rv12 Harvey rv12 is offline
Default prop bolt torque
Question;
Are all you RV-12 owners removing the spinner and checking torque of the prop bolts every 25 hrs?, seems like a frequent inspection to me. 4 times per oil change.
Your thoughts ??
Tom O.
Old 10-16-2015, 01:19 PM
JBPILOT JBPILOT is offline
Default I think this answers that - -
http://www.sensenich.com/files/docum...1314811785.pdf
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-2020 )
Old 10-16-2015, 01:38 PM
Default my bad
I see it was revised out of the maintenance manual. It was every 25hrs, and now it is at each annual condition inspection.
I feel a little better now!.
Old 08-07-2019, 01:47 PM
HansLab HansLab is offline
Default safety first
...It keeps bothering me though that nor Van's nor Sensenich supplies bolts to be finished with safety wire. I just torqued my prop for the first time, but I'm ordering some more washers and will use drilled bolts next time I pull the spinner.
Hans Labruyere
build & sold project Kitfox IV
Project bought & building RV12 #120742
Donation 2020 paid
Old 08-07-2019, 03:17 PM
rvbuilder2002's Avatar
If you do a bit of research on Nordlock washers, you will find that they are quite reliable as safetying devices.
I have been working with this prop on RV-12's for 12 years now and have yet to find a loose bolt when checking during inspections, etc.
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Scott McDaniels
Van's Aircraft Engineering Prototype Shop Manager
Hubbard, Oregon
Old 08-07-2019, 07:55 PM
If each pair of Nord Lock washers is installed correctly with the beveled sides facing each other, it takes considerably more torque to loosen the bolts than it did to tighten them. They are not going to loosen up on their own. The same wedge lock washers are used on the brakes. I even used those washers on engine mount bolts.
Joe Gores
RV-12 Flying
Old 08-08-2019, 05:26 PM
Bob Y Bob Y is offline
Folks might be interested in this video.
https://www.youtube.com/watch?v=IKwWu2w1gGk
Bob Y - builder 12iS
N569TT first flight 2/9/2020
Old 08-09-2019, 08:37 AM
Impressive movie, Bob - thanks for sharing. I feel safer, now.
Hans Labruyere
Donation 2020 paid
Old 08-09-2019, 09:13 PM
Yep, pretty cool, Bob. Thanks.
Old 08-10-2019, 01:26 AM
Default re-use lockwashers
the film confirmed my thoughts that a lock washer-couple isn't to be re-used: the angles will tear. Are there any given times one could re-use these washers?
Hans Labruyere
Donation 2020 paid
