Old 10-15-2019, 06:32 AM
Originally Posted by flysrv10 View Post
Have sent her direct email too. perhaps I have the wrong email.
I'll check with her. One of the nice aspects of working these plastic parts with Amanda is that we communicate more than we would otherwise.
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 800+ for all
My Artwork is freely given and published and cannot be patented.
www.rvplasticparts.com
Old 10-15-2019, 09:36 PM
Default ABS and Carbon fiber filament
a nice tactile feel material. stiff, lightweight, and beautiful. relatively quick to print.
Old 10-16-2019, 04:21 PM
Default ABS and fiberglass filament
similar feel to carbon but not the same. lightweight and stiff.
Old 10-20-2019, 07:21 PM
Default Spark Plug Lead Baffle Seal
checked the torque on the copilot side and it was OK. it had one re-torque since installation. re-torqued the pilot side for the first time, it had lost some torque since the install. I'll check the torque again at the next oil change in 50 hrs.
Old 10-26-2019, 06:19 PM
Default Prop pitch angle tool
Old 11-02-2019, 04:55 PM
Vlad Vlad is online now
Fairlead pair installed on a project in Arizona.
Another set is flying in New Jersey 15 hours +
A lot of those needed
Old 11-11-2019, 08:55 AM
Vlad, I noticed you use a bigger head screw. That's the right approach for these. I followed your lead.
Old 11-11-2019, 08:57 AM
Default LightSpeed Zulu3
LightSpeed Zulu3 headset controller mount in progress.
one of the best complex corners I have made.
Old 11-12-2019, 02:27 AM
This headset goes back to the owner tomorrow. A record two day turnaround. It is a very good fit. Approved for aerobatics but easy to remove. I like it and I know the owner will too.
Note for printed parts: when you see some stitching marks on a flat surface at the perimeter edges you know the previous layer is overlapped at the edge with the current layer by some amount. this stitches the edges together to form a superior bond. the stitching marks typically fade away from the edges. I always look for this on on the flat surfaces of printed parts.
Old 11-13-2019, 05:23 PM
Default Fuel Sump Tester Mount
Kicking around a concept for simple fuel sump tester mount. I think I would test more frequently if the tester was easier to access.
A beginning concept.
taking a look at bending stress in the retainer. plan to mathematically determine the optimum beam taper for uniform bending stress as a fun endeavor. MATLAB will be used to help with this.
this is looking good from a stress perspective. the key is to allow the bottom plate to flex and do some bending. spread the load with a big asymmetrical fillet that essentially creates an elliptical shape. I also blended the lateral restraint pocket to act as a guide.
I like it. I'll install it for testing. Weight is only 30 grams. ASA plastic, UV resistant. secure but easy to remove. anti-rotation feature. attach with velcro. it should have a long life. plate is recessed to fit cap end but will accept testers with no cap end. mount it vertically and it would serve to be a good location for gasohol testers that require a 10 minute wait time.
installed. I like it. the only thing better could be a funnel fit at the tip for returning the tester to the mount. since it is a blind return for me a funnel fit at the tip would be beneficial. I'll see what I can do. installed with duel lock velcro. this sump tester is literally at my fingertips. no more excuses for sumping the tanks. Master Sargent Ray Parker is in to have a look. I stand as straightly as I can. Ray sumps his tanks at every fill.
new lower pocket for ease of finding in the dark. just get it close and it will find the home. some complicated geometry in there, amazing.
a nice part
