Go Back   VAF Forums > Regional Forums > International
Old 06-04-2020, 07:45 AM
Staunch Staunch is offline
Originally Posted by PaulvS View Post
In Australia the situation is similar, all of those products are imported and unless there is enough volume to make it worthwhile for a local retailer, you need to be prepared to order it from the US and get it sent over. Aircraft Spruce carries most of those products and you can also get the Proseal from Vans and the Ekoprime direct from Stewarts.
An alternative for the surface protection products is to use a 2-pack epoxy primer, which you should be able to get locally from an automotive paint supplier. Brands like Nason, Valspar (Resene?) may be available and suitable.
The downside to importing is the shipping cost, I ordered $300 tools from yardstore.com and the shipping cost $100. Ordered on 21 April and received on 11 May, which is not too bad considering global flight reductions due Covid-19.
Good luck!
I have been able to buy Alodine and AlumiPrep in bulk from a Sydney supplier. From memory, $400 worth of product was more than enough to do 3 full airframes.
Old 06-22-2020, 02:20 AM
NZRV7ER NZRV7ER is offline
Hi Ian
For alodine PPS industries Ltd (09-5791001) in Auckland sell it in 3.8ltr containers for around $140ish.
Craig
