Old 01-12-2009, 01:32 AM
N24YW N24YW is offline
Default Fuel sender leak
My fuel sender is leaking. The gasket has swelled up some and it seems to have some blue stains on the sending unit. My question, is it possible to remove the sender on a Rv 6 with out pulling the tank off of the wing. My plan is to try to use tank sealer and no gasket.?/
Jim Knight
Burlington Iowa
Old 01-12-2009, 02:09 AM
gasman gasman is offline
Yes! And then you can cut the the gasget with a plastic kinfe to remove the sender unit. When you re install it, just use pro seal and no gasget.
Old 01-12-2009, 08:29 AM
az_gila's Avatar
az_gila az_gila is offline
Smile ...and use....
...socket head cap screws when you re-install the sender.
Much easier to get at in the restricted space than philips head screws if you ever need to get back in there.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-12-2009, 06:42 PM
Jim Lewellyn's Avatar
Jim Lewellyn Jim Lewellyn is offline
Default Yes, but.....
You can do it with the tank in, but........It is difficult get your hands in there to work, and it is very hard to clean the surfaces between the sender and the tank. It only takes a few extra minutes to remove the tank, throw it up on the bench, and work on it with ease.
Jim Lewellyn
N6312V
RV6 - O-320 FP
GRT Sport & GRT AP
Old 01-12-2009, 08:35 PM
Mel's Avatar
Mel Mel is offline
I'm afraid I have to agree with Jim on this one. I've done it both ways, and on a -6, I will never again try to do it without removing the tank. I's so much easier. You can remove and reinstall the tank in less than an hour and you will save more time than that by doing it this way. Plus you will do a much cleaner job.
Mel Asberry, DAR since the last century.
EAA Flight Advisor/Tech Counselor, Friend of the RV-1
Recipient of Tony Bingelis Award and Wright Brothers Master Pilot Award
USAF Vet, High School RV-12 Project Mentor.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-24-2010, 11:59 PM
flyboy1963's Avatar
Default pulling tanks not easy
sounds easy if you say it fast. As I don't have a hangar, and not being the builder, dont' have a lot of fancy tools, would you still recommend pulling the tanks? I'm concerned that I won't get the fuel line and vent lines back together as good as they are now; in fact, is there enough 'slack' in these rigid lines to actually separate the flare fittings, to allow the tank to 'swing' free?
I'm sure doing them in place is a huge pain, but I'd rather not pull them if I don't have to.
your words of wisdom appreciated.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 05-25-2010, 06:00 AM
Mel's Avatar
Mel Mel is offline
Default Like I said,
It can be done in place. If you DO decide to pull the tank, remove the "B" nuts first. Don't try to remove the tank and THEN undo the lines. The lines are not long enough to flex much at all.
Old 05-25-2010, 07:18 AM
flyboy1963's Avatar
Default good advice
thanks Mel,
I already bought the hex head screws for the last leak 'fix'. Now just the 'gasket or not' decision. I'm leaning towards just coating everything with Permatex aviation form-a-gasket. Actually, I don't think i CAN put a gasket on with the tanks in place.....won't be able to slide it over the float?
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 05-25-2010, 08:14 AM
JonJay's Avatar
JonJay JonJay is offline
Default Here is a link of how I did it.
http://www.vansairforce.com/communit...ht=fuel+sender
I hope you find it useful. On my 6, I did not want to cut away the paint on the tank screws to remove the tank. Be prepared for a very messy job here as it is tough to get your hands in there and the proseal where it is supposed to be. Outside of the mess, it is a very simple job.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-25-2010, 09:09 AM
LarryT LarryT is offline
+1 for tank removal. The tank was remarkably easy to remove (especially compared to my Cherokee tanks, which I had to remove to address an AD). I am convinced based on personal experience that the job is actually faster if one removes the tank.
LarryT
