New Panel RV-7
ConnyJ35
I'm New Here
I am in the process of designing the panel to my RV-7, after a lot of thinking and questions I have come up with a draft. I´ll be glad if I can get some comments.
The setup consists of two G3X, one G5, GNX 375, GTR 225 (8,33) and GMC 507, ELT and CO detector. No CB´s, Vertical power VP-X will take care of that and other things as WigWag and different warnings.
One concern is the placement of Parking brake and Cabin heat. I have seen comments that they are preferably mounted on detachable panels to make it easier to remove the panel, if a such an operation should be necessary.
I have also been recommended to have an extra oil warning light if the primary sensor should fail.
Not quite sure about the Master/Alt/StartSw/Key switch placement.
So, now I hope I got it right with the picture, if clicked it will open in a larger version.
