GRT S100 Slave question
edclee
Patron
Does anyone know if a GRT S100 slave unit used by itself can get info from the EIS 4000 and display that info? I dont need for it to do anything else, just engine information.
Yes, the GRT S100 will display the engine information produced by the EIS. The only difference between the S100 and S200 is the S200 has pitot/static inputs and an AHRS. The S100 will work as a moving map (with GPS), engine monitor, and will display CDI/HSI if fed from a proper source (ARINC module may be needed depending on source).
Thanks Mike
